What do I do with the steering column now?
Ok guys, my M-20 is almost done being built and I'm going to be putting it in not this weekend but the next. after i take the 3spd linkages out and the handle off the column, what do I put in place of the 3spd collar that goes around the steering column? I don't want a collar that spins around or has an unsightly hole in it from where the level stuck into the side of it. Is there a special solid one that came with trucks that had a 4speed from the factory? If anyone has the part I need PM me with a price and maybe I can get it painted in time for next weekend. Thanks in advance guys!
Joe |
Roadtrip!
![]() Join Date: Feb 2003
I think i have a column for ya, but will have to check later today. And i will be in coon rapids on friday the 9th. Will let you know what i find.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
![]() Join Date: Aug 2001
![]() YOU NEED A STEERING COLLAR OFF A 4 SPEED COLLUMN. YOU SHOULD BE ABLE TO GET ONE FOR AROUND $10 ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Are the collars that hard to replace?? I've taken my column apart as far as the steering wheel and that's it. That only takes a couple of minutes. How much further beyond that to remove the old collar and install the new one?
Joe |
Resident Curmudgeon
![]() Join Date: Dec 1999
Been a while but I do know you need to pull turn signal switch, flasher, and associated wiring before the collar will slide off. Theres probably a bearing in there too.
Carefull with the hazard switch and wiring.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
For now until I feel like tearing all that apart, can I just knock that dowel pin out where the 3spd lever goes into the column and remove the handle? Then take care of the collar later? Otherwise I'm sure that thing'll be in the way.
Joe |
its all about the +6 inches
Yeah, you can do that, the collar won't mess with anything and you'll even forget that the nub is there.
![]() IT'S NOT TUFF AT ALL.... & PRETTY WELL SELF EXPLANITARY. ![]() ![]()
John, if you'd like to sell me a straight stick steering column collar for $10 + shipping to zip code 55369, consider it sold. Do you have any? I'm not a body man by any means so a dent/rust/gouge free one is preferable
![]() Joe |
![]() JOE .... I DON'T HAVE ONE RIGHT NOW, BUT I WILL GET YOU ONE WITHIN THE NEXT 7 TO 10 DAYS. I'VE GOT A COMPLETE 4 SPEED COLLUMN & I HATE TO PULL THE COLLAR OFF OF IT , BUT IF I DON'T FIND YOU ONE I WILL. WHERE IS 55369??? JOHN
Roadtrip!
This is the only one i have right now. Let me know if you are interested. As i said earlier, i will be in coon rapids on fri. I consider this a parts column because it has been sitting in the weather.
4 spd steering column
PM'ed you too much stuff.
Joe |
Roadtrip!
Didn't recieve pm...
