04-05-2004, 09:33 PM | #1 |
The LuvShack Garage
Frt. Clip Problem
WELL I STARTED TEARING MINE DOWN TODAY AND HIT A SNAG,
THE 2 BOLTS ON THE TOP RIGHT FOR THE FENDER BY THE DOOR HAD BOLTS SPINNING, TOOK A DRILL AND DRILLED THE HEADS OF THE BOLTS OFF, DID I SCREW UP? OR CAN I GET THE REST OF THE BOLTS OUT OF THE BACKSIDE? THESE 2 HOLES WHERE NOT THREADED SO IT HAPPENED TO THE PREVIOUS OWNER 2.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
04-06-2004, 11:58 AM | #2 |
SKINNY TIRES RULE!
I'm not exactly sure where your talking about but some of the bolts have speed nuts on them.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
04-06-2004, 07:09 PM | #3 |
Member since 2000
are you talking about the one closes to the door in the photo?
04-06-2004, 09:01 PM | #4 |
The LuvShack Garage
exactly
04-06-2004, 09:15 PM | #5 |
you can cut it out and weld in new nuts and it will be good as new. hope this helps. later
John |
04-06-2004, 09:23 PM | #6 |
I am a Gov't Mule
Off topic/ Alexis
Dig first, money later - what movie is this line from?
clue:he was talking to the priest Is that The good, the Bad,and the Ugly???
...to die in the saddle must be my destiny, to ride this rockin' horse I must be crazy... |
04-06-2004, 09:34 PM | #7 | |
Member since 2000
Re: Off topic/ Alexis
04-06-2004, 09:35 PM | #8 | |
Member since 2000
04-10-2004, 10:45 AM | #9 |
stripped bolts
Hey,
You may wanna try nut-serts. These things are real neat.The tool looks kinda like a pop-rivet gun.It has different threaded ends you put in it,the same size as your bolts.Then you screw on the end w/the nut-sert.It looks kinda like a top hat and is aluim.w/threads in the middle.You drill the hole in the body the same size as the outter part of the nut-sert.Put the nut-sert on the end of the tool.slide it in the hole you drilled and sqeeze the handle of the tool and the nut-sert squeezes itself between the sheet metal. An instant threaded hole. They are not expensive at all. I think you can buy them at like in a grainger catalog or mc master-carr. they save me alot of trouble. Hope i can help Tom |
04-10-2004, 05:13 PM | #10 | |
How about "The Count of Monte Cristo"?
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
04-12-2004, 02:02 AM | #11 | |
Member since 2000
Re: Re: Off topic/ Alexis
Yup |
