04-06-2004, 03:23 AM | #1 |
Please look......
i was surpine that 73 to 87 gauge cluster has differnt style
for mph and rpm is that factory made that way???? pls look link.. http://cgi.ebay.com/ebaymotors/ws/eB...472269871&rd=1 |
04-06-2004, 03:57 AM | #2 |
Professional Grade
Cool!
I like it!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
04-06-2004, 09:38 AM | #3 |
Slots go on anything!
The speedo and tach are out of a 70-73 Trans Am. It looks pretty trick in there. I had seen late 70'2 Camaro tachs put in 67-72 clusters before, but I like this better.
1974 Jimmy- 5.3/4L80e/NP241 |
04-06-2004, 11:17 AM | #4 | |
Happy to be here
Unless you are a gambler, I would steer clear of it...
04-06-2004, 11:58 AM | #5 |
www.73-87chevytrucks.com
It should work. GM (as strange it may sound) were pretty "standard" on their connections. The tach for the F-body will have the same leads and the Speedo only needs a cable. I am just curious as to why he didn't indicate that they weren't real 73-87 gauges. Plus the fact that the speedo and Tach don't match you other gauges.....
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
04-06-2004, 12:14 PM | #6 |
It followed me home?
160 mph speedo in a truck just seems kinda dumb to me. I put a 100 mph and its a waste too.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
04-06-2004, 12:22 PM | #7 |
I don't know about that! I outrun my 100mph speedo quite regularly.
04-06-2004, 12:35 PM | #8 |
Oh,you can't buy that new
I'm too tired right now(night shifts again) to get into all of this but Don't fall for it . I've measured those early T/A gauges and MANY many other gauges and nothing factory is as large as ours. he is not showing close enough of pics to see the gap that may be all around the opening. plus there is no 'slight' rewiring in the 73-87's . he has the typical unknowing statement of 'fits all 73-87's' and I can't tell you enough of how wrong that is . He has others up for bid and one has the 7K tach in it and he says it's in perfect working order and it's missing two mounting tabs , one of them a major mounting point, and it's guide for the gear indicator string is broken completly out and that can't be fixed. Plus no pics of how cobbled up the back side of them is . 'caveat emptor'.
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. Last edited by crossy; 04-06-2004 at 12:42 PM. |
04-06-2004, 12:42 PM | #9 |
Hey Crossy I wanted to thank you for the write up you did on the factory tach stuff. I just added one and the info you put on 73-87.com really helped a lot.
Adam
04-06-2004, 12:58 PM | #10 |
Insert Witty Text Here
Here is one installed:
http://www.cardomain.com/memberpage/563861 The site says "'79 Trans Am speedo and tach (use a Dremmel tool and some RTV to do this!)." Slonaker |
04-06-2004, 10:31 PM | #11 |
interesting!!!......
04-06-2004, 10:38 PM | #12 |
LED King
My 85 mph gauge is too small. I find myself often at 85 or above in the black space on the freeway.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
04-06-2004, 11:02 PM | #13 | |
You get what you pay for
Mike 1985 Chevy C-10 |
04-07-2004, 11:07 PM | #14 |
Rollin' Member
where is a good 'cutting edge' pun when you need one.
:: 1977 C10 cheyenne :: :: 1973 new yorker brougham :: for sale - $1,500 lofat productions |
04-07-2004, 11:39 PM | #15 |
Professional Grade
I dunno about you cochino -- but even I can peg my 100 mph speedo, and thats with a totally stock truck with a half 3.73 and half 4.10 rear end, lol
04-07-2004, 11:58 PM | #16 | |
yeller
Most aftermarket tachs are 100+, so unless you want to use a stock GM one, there isn't much you can do. I wanted to thank Dave too, the tach article is great. It still needs some tweaking, but he and I can work on that. I have also been adding example pics as I find decent ones to use. I would ideally like to find an example of every year or different variation. Here is the link in case it has changed since the last time anyone was there.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
04-08-2004, 06:43 AM | #17 | |
