Old 04-09-2004, 04:27 AM   #1
Tom
driving is in my blood
Tom's Avatar
c-notches suck to install
I decided after more then a year with the flip kit that I wanted to put my c-notches on. Couldn't be too hard, and besides, Mike did it with a sawzall so I hopfully could too.
Big mistake.
Mike, I gota give it to you. Your skills with the sawzall cannot be compared. Hell, if it wasen't for my friend Jason helping I wouldn't have gotten even half way on sawing that frame off. As it sits, its an ugly cut on both sides, and they are just a tad too far foward. Not enough to affect anything [I think ] but if you check you can tell. Anyways a warning to everyone: do not attempt this install with only a sawzall and a single 1/2" drill bit and WD40. It works, but it ain't pretty
Old 04-09-2004, 12:50 PM   #2
1FaastC10
1FaastC10's Avatar
i used a Matco Red Line Anti Vibration air saw to cut my frame to put the 81+ bumper on it. part no RL 1325 if i remember correctly. cut through it like a hot knife through butter. yet another case where you get what you pay for.
1FaastC10 is offline   Reply With Quote
Old 04-09-2004, 02:43 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Yup, one reason I bought an air compressor.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 04-09-2004, 03:51 PM   #4
TIMSPEED
TIMSPEED's Avatar
Also a reason to know someone who has a Plasma Cutter
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 04-09-2004, 06:00 PM   #5
PHOENIX
Anyone ever used an air body saw to cut a frame?
I know most are only for 16-18 gauge at the max., but I am sure it would work. Has to be easier to handle then a sawsall.
Plasma is the way to go. Too bad they cost so damn much.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 04-09-2004, 09:20 PM   #6
low 84
low 84's Avatar
angle grinder with 4 inch cut off wheel.
i've done 2 truck like this and the cuts come out near perfect. i'm pretty good with a grinder though
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 04-09-2004, 09:38 PM   #7
BaggedC10
Under construction!
BaggedC10's Avatar
I used a Craftsman cut-off tool w/ great results on my 86' C10.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 04-09-2004, 11:25 PM   #8
cochino12
It followed me home?
cochino12's Avatar
You guys need to come to colorado and help me with mine. I'll buy the beer
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-10-2004, 03:39 PM   #9
84Stepper
84Stepper's Avatar
ha.. I used an angle grinder also and it was a pain in the butt. The hardest part to me was drilling all the dang holes. I went through 2 brand new drills.
84 Chevy Stepside, 350, TH350, 268h
Comp cam, Hooker headers, MSD
Pro Billet, Edelbrock Performer manifold
and 1604 carb, 40 Series Flowmasters
dumped, and Western Chassis 3/5 drop w/ c notch. New 3:73 Eaton Posi
84Stepper is offline   Reply With Quote
Old 04-10-2004, 04:02 PM   #10
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
I have a flip kit on my 77' and I just put 2 inch shackles on it . I had to c-notch the frame. I used a grinder with a cut off wheel on it, what a pain in the ass. Then I welded 1/4" steel to the frame for the notch. Then I put my bed back on and the damn rearend hits the bed floor when I jump on it so I had to notch the bed floor also..... lots of work for 2 more inches but well worth it. The rear looks so much better now and its still not that low cause' my rear tires are 31" tall
Grande Rojo is offline   Reply With Quote
Old 04-10-2004, 04:22 PM   #11
1FaastC10
1FaastC10's Avatar
did you read my post at all?
Old 04-10-2004, 06:14 PM   #12
Tom
Tom's Avatar
Youd be amazed at how much more the drill bit would have drilled if you had someone spraying down the bit/hole with WD40 as you drill. I couldn't believe the difference.
Old 04-10-2004, 06:34 PM   #13
78chevstepside
78chevstepside's Avatar
I like metabo grinders with 5 inch cutting disc . these work great for cutting. metabo grinders are one of the best electric grinders on the market. For fine cutting air powered 90* angle peanut grinder with thin cutting discs work great. cutting torch ( oxyacetylene)work great also. Even for burning the holes for the bolts. a torch works just as good as a plasma cutter. I leave the plasma cutter for stainless steel. I cut my c-notch with a oxyacetylene torch. Buned the bolt holes with a torch.
78chevstepside is offline   Reply With Quote
Old 04-10-2004, 09:38 PM   #14
PHOENIX
I thought I did, but now that I look at it, I dont know what I was thinking
I just bought a cheap air saw a few months back and havent used it much, but it seems like it would zip through a frame no problem.
I use my 4" grinder for cutting everything. If you use the cut off wheels you can get a cleaner cut then the grinder wheels. The flap discs work great for cleaing edges and blending in welds.
When drilling through steel, a good bit and cutting oil is the key.
The right bit and some cutting oil make it much easier, faster, and a cleaner hole.
The cutting oil keeps the bit cool and makes it last much longer.
You can buy a little bottle of the cutting fluid at Lowes/HomeDepot and just dip the drill bit in the bottle before you drill each hole.
Old 04-10-2004, 09:39 PM   #15
TIMSPEED
TIMSPEED's Avatar
That's what I used to take off my factory bumpstops. I had a friend hit the brackets with a hammer, while I heated up the rivets. The brackets came off nice and clean.
See Them Here
Old 04-11-2004, 02:18 AM   #16
swervin ervin
You get what you pay for
swervin ervin's Avatar
I'm not sure what was so hard about using a sawzall. Worked like a charm for me. I tried a 4" side grinder with cutting wheels but liked the sawzall better.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 04-11-2004, 05:31 PM   #17
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Another big mistake alot of people make is drilling at a high RPM setting.
When drilling steel you want to drill at a very low RPM setting if you do this your bit will last a very long time.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
