A/C Pulleys on a 72 Small Block?
I'm adding A/C. Is the crank pulley a three groove style with the outer groove larger in diameter?
Is the water pump pulley a two groove and both are the same diameter? I've got access to a couple of donor vehicles, not all 67-72 but the pulleys look similar to me. Opions and pics welcome! Cheers, ![]() |
Both sets of pullys are the same diameter. I can get numbers off of the pullys if you need them.
Be careful mixing pullys as you can end up with misaligned belts. Jim |
Jim,
Thanks I am concerned about that. I don't have all the compressor mounting brackets yet so I'm doing this kinda blind right now. If it's not to much trouble numbers would help Gary |
Gary, the water pump pulley is the same diameter with 2 groves. The crank pulley is actually 2 pulleys, one sets inside the other and both are same diameter. inner pulley is single grove and outer is 2 groove.
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
Bill,
Thanks! I may be coming up to see you. Do have compressor brackets and maybe pulleys? Gary |
Gary, I have brackets, maybe pullies, I'll have to check.
Here are the part numbers for the crank pullys and the water pump pulley.
Water pump pulley is a double, PN 1235778 Crank pulley, inner double, PN 3744043 BA Crank pulley, outer single, nests into inner, PN 3751232 Here is a pic, sorry about the quality, I have trouble with black parts as they don't show up well. Jim |
Thanks Jim that helps alot. I see now the donor vehicles aren't the same.
Gary |
