04-11-2004, 02:33 AM | #1 |
400sb starter problems!!
I have a 400 small block in my 4x4 and the starter makes lots of noise when you crank it. I tried shims and got no where. So today I got a new starter, same thing!! Put some shims in it and still very noisy!! Could I have the wrong starter?? I have never messed with a 400sb before? The truck cranks and will start, just very noisy. The fly wheel has some minor wear on the teeth, but nothing I would think would matter?? Any ideas???
Thanks, Joe
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
04-11-2004, 03:34 AM | #2 |
huh?
Just a random thought on this....
My friend had a 307 in his 68 Chevelle, and had put a reman starter in it. It made one heck of a noise when it cranked, but it would start and run.... It turned out the starter was for a different tooth count flywheel. Does that make sense I know some SBC's had 153 tooth, and some had 168. Couldn't tell you which had which tough. Good luck.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
04-11-2004, 05:00 AM | #3 |
Cure for noisy starter on sb400's:
step 1: remove starter 2) remove sb400 3) take sb400 to deepest lake in your area, and pitch it in. 4) procure sb350,327,307-any other small block, rebuild if neccisary, and reinstall 5) reinstall starter Problem solved. Even if your starter still makes noise, the bigger overall problem is solved. That starter won't overheat no more, either least that's my .02 |
04-11-2004, 09:05 AM | #4 | |
Watch out for your cornhole !
04-11-2004, 11:39 AM | #5 |
PROJECT 7DEUCE
No wonder I can't find a 400 bottom end for a stroker, they are all in a lake some where???
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-11-2004, 01:01 PM | #6 | |
04-11-2004, 02:30 PM | #7 |
The starters are completely different in how they mount. One has straight across mounting bolts and the other has offset mounting bolts.
You just compare the new starter to make sure the aluminum nosecone with the bolt holes is the same.
04-11-2004, 09:01 PM | #8 | |
04-11-2004, 09:27 PM | #9 |
Find a starter like this they have a cast steel nosecone and get the font brace to.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
04-11-2004, 10:31 PM | #10 |
The LuvShack Garage
MY 67 THAT I'M SELLING HAS A 400 SB AND IT DOES THE SAME
THING, TRIED SHIMS ALSO, I'M JUST ROLLING WITH IT AS IS.
04-11-2004, 10:46 PM | #11 |
I have a 71 blazer with a 350 that I have had 20+yrs it went through starters and flywheels like water, Shimed it in every direction. 2 Things ne is the brace that mounts on the back to keep it from flexing. The other I used the remanufactured starters from what was trak auto here in VA Lifetime warranty stuff. Bring it in and get a new one. Anyway I had to have the transmission rebuilt and the guy told me that there was a big difference in the quality of parts used in a trak auto starter versus a percision starter $ 30 versus $110 for the percision anyway the percision starter has been on there 8-9yrs now. before I was getting a starter every couple of months. Also I had a sm400 that came in a 70 monte and it never made a sound
