Old 04-11-2004, 11:52 PM   #1
GMC69
GMC69's Avatar
front suspension?
Now I know this has probably been asked before but I needed a bit of info.
I currently have a 69 with drums up front and 6 bolt.
I want to convert to PB and discs up front. I have a 78 ( front suspension) and an 83 Chevy truck that I can get parts from.
Do I need the entire front suspension off one of them or can I take only a couple parts to be able to use the front spindles so I can use the disc brakes. I don't really care if it stays 6 bolt or goes to 5 at this point.
I know i is supposed to be fairly simple to swap the entire front cross member but I was just curious what my be plan of attack would be.
Mike
Email: Click here to email me
2019 Silvedrado 4x4
1970 Chevy 3/4 ton, 396BB, on air bags
GMC69 is offline   Reply With Quote
Old 04-16-2004, 09:37 AM   #2
phestus
Being here doing that..Mine's a 70', with a donor 81 pickup..
Currently I'm swapping out the old A arms for the 81 parts, and I'll use the disc brake spindle ..Supposedly the balljoints to fit the 70 A arm are more expensive and smaller..
I was going to do the crossmember, but when buddy dropped the parts off, he had only brought the A arm assembly..The crossmember does swap right onto the old frame , however..
Other issue you'll run into is mating tie rods, etc from old to new, but if you make sure and get EVERYTHING for steering and braking off the donor truck, you can save yourself a lot of problems.
'70 C-10, mostly rust n' dust
'74 BMW R90/6
"The quickest way to get yourself out of a hole, is to stop digging..."
phestus is offline   Reply With Quote
Old 04-16-2004, 08:16 PM   #3
Faster_than_you
yes it has been asked before, and I am in the middle of switching also. actually from 8 lugs to 5 or 6 lugs. but today I found a jag irs! so looks like just dropped spindles, and rotors for the front. and a few upgrades for the rear.
~Christopher L. Orr
71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc.
Faster_than_you is offline   Reply With Quote
