Old 04-13-2004, 11:10 AM   #1
angelsairman
Future Owner
angelsairman's Avatar
Question Anti-Freeze in Oil..Please Advise
Ok guys need some advice, posted this in the Engine forum but also wanted to post here as i usually get the most response...Built a 350 for my 71 c10....installed it, starts fine but it looks like im getting antifreeze in the oil...the oil on the dipstick has risen about a quart and the oil now has a greenish tint to it....the engine has only been ran for a total of about 20 minutes so far....im thinking possible bad seal on the head gasket or blown head gasket??? Where else does the oiling system and the coolant system cross paths were there could be some leakage into the oil???? Please shoot me some advice here..im going to drain the oil tommorrow and start with some fresh oil...
Its not the end result that counts most...its the journey along the way that's most rewarding
My truck doesn't leak, it just marks it's territory
angelsairman is offline   Reply With Quote
Old 04-13-2004, 11:26 AM   #2
72LOWBOY
It could be an intake gasket leaking, that would be alot easier than pulling the heads off. Wishfull thinking..good luck
72 Chevy LWB leaf spring rear,SBC 385 Fast Burn,Art Carr built 700r4,3.73 Eaton posi,one piece windows,lowered 4/5.5, 60/40 seat, shaved turn signals,shaved reverse lights,shaved stake pockets, stainless steel 21gall in rear, c-notched, vintage air,ps,pb,currently doing body work.
68 Camaro conv.327,turbo 350,pb,disc brakes,built it for the wife
38 Chevy Coupe on the back burner
LIFE IS GOOD! SMILE
72LOWBOY is offline   Reply With Quote
Old 04-13-2004, 11:39 AM   #3
gerry giordano
gerry giordano's Avatar
Possible causes:
Damaged head gasket
Cracked head
Cracked block (and with heavy duty engines)
Leaking oil cooler
Leaking cylinder inner seals
Leaking injector seals (if you have them)
If you haven't done so already, do a compression test. If you find some weak cylinders, do a wet test by squirting a little oil in the low cylinders. If there is no compression increase, particularly in two weak side by side cylinders, I'd be suspicious of my head gasket.
'69 C-10 LWB, 350, TH350, posi-traction
gerry giordano is offline   Reply With Quote
Old 04-13-2004, 02:31 PM   #4
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Check your oil cooler.
67Fleetsidedream is offline   Reply With Quote
Old 04-14-2004, 12:28 AM   #5
kwmech
I would lean towards the intake gasket myself if it is still green.
Gasket probably slipped down when you set the manifold.
Old 04-14-2004, 12:40 AM   #6
Blue_71
Bloo
Blue_71's Avatar
friend of mine had that problem with a 305 i traded him, he didnt torque down the heads
just an idea
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 04-14-2004, 01:33 AM   #7
rn2fine
rn2fine's Avatar
Intake gasket sounds most likely to me. What kind of heads are you running? Are they Vortecs?
72 C10 Burb 350 700R4
70 C20 LWB 350 Crate TH400
68 Chevelle
rn2fine is offline   Reply With Quote
