04-13-2004, 07:33 PM | #1 |
C10 now is a GMC
Brake drum adjustment
Hi Everyone,
Even though my truck is a '62 the drum brake adjustment should be the same as the '67s-70 trucks right? If so what should be the propper brake adjustment (star turns)? TIA, David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
04-13-2004, 07:57 PM | #2 |
Wiseass secured himself a BAN
Should be the same. Adjust the brakes to where the pads are barely rubbing the drum.
04-13-2004, 08:05 PM | #3 |
Before and After
I just usually get them close to the drum, and then use the adjusters to do the rest automatically.
Just roll the truck in reverse(slowly). and hit the pedal, to get the brakes to grab the drum, and it in turn muves the lever onto the adjuster, do this a few times, and the will be set perfectly every time. Evrey time you hit the brakes in reverse, it will tighten up the adjuster, but only when there is enough room for the brake shoes to move.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
04-13-2004, 11:59 PM | #4 |
I just did my drums over the weekend and am wondering if it is normal for the drums to slightly contact the brake shoes after the auto adjust is done. With tires off the ground, when i spin the wheels there is just a hint of the shoes contacting the drum at one spot on each wheel. Is this anything to be concerned with? Thought it might be relavent to "Chevyboy"s question also.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air 2000 Harley...Wide Glide |
04-14-2004, 12:02 AM | #5 |
By the way, I did mine just as WB72 stated and it worked just fine.......other than the small bit of rubbing of the new shoes.
04-14-2004, 12:23 AM | #6 |
its all about the +6 inches
slight drag is normal.
