Ls7 in a 84 Sierra ?????
i bought a crashed Z06 is completely useless from the back the chassis had damage so i thought of adding the ls7 to my 84 square body is it to much of a Hazel or is it worth trying or even possible
Posted via Mobile Device |
Re: Ls7 in a 84 Sierra ?????
You will need a different trans because the corvette has a transaxle in the rear,But you will need a few things like http://www.brphotrods.com/mm5/mercha...ory_Code=CNV10 and if you want ac a few companies like http://www.kwikperf.com/lsx_ac.html to keep it drive by wire takes a little more work like http://www.lokar.com/product-pgs/new...e-by-wire.html or use a oem gas pedal.
thanks great help ....but i have another question would i be better of putting something else in or is this motor a good addition because i don't wanna strougle to much with conversions
Always a work in progress
It would make for a great motor in your truck. Just throw a 4l80e behind it and terrorize some local ricers!!
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
I'm just glad to be here!
The conversion to the LS7 would be great. It is a bit of work and not one that coild be done in a weekend if it is daily driver. Check the LSx section in the Engine part of this forum. There is a ton of good info in there. Keep us posted!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
