09-21-2015, 06:03 PM | #1 |
First start of my 84 C10 383 in over 5 years.
Hello all, I'm not new here, but this is my first post. Before talking about todays start up, I would like to give some history of my truck. I've owned this truck for 15 years. It started life with a 305, and a TH350c trans. I got it with a blown head gasket. I replaced the head gaskets, and it became my work truck. While it ran ok, the 305 was gutless, and it burned oil. Well, after a couple years, I bought a brand new Mr Goodwrench 350 for it which ran sooo much better. Although I had a hopped up 88 Mustang to get my performance fix from, I couldn't help but feel my truck could still use a little more power. I ended up putting a set of the cheap chinese Pro Comp aluminum heads on it, along with a Comp Cams 268 cam, as well as an Edelbrock performer intake with a Holley 750 vacuum secondary carb. It was much stronger than before, and I drove it like that for several years. Somewhere along the line the TH350c went out, so I did a 700r4 conversion with a mild shift kit.
I'm a family man with four kids, and things started getting tight, so I sold my Mustang, thinking I had no need for toys like that anymore. Man was I wrong! It wasn't long after that I started building a motor from scratch for my truck. The build list was this. 010, 020 high tin, high nickel 4 bolt main 350 block that still had a STD bore. Had it bored .030, and honed with torque plates, as well as being stroker clearance. All machining done by Deleon Racing. Scat 9000 crank with the aero counterweights. Scat 6" I beam rods Manley forged flat top pistons. Rotating assembly also balanced by Deleon Racing. Brodix IK200 heads, with 70cc chambers. 10.25 compression ratio. Pocket ported, and gasket matched. Lunati VooDoo 60104 flat tappet 504/525 lift cam. Harland Sharp roller rockers (1.5) Edelbrock RPM Air Gap intake. Holley 750 double pumper with contoured main body. I also installed a ram air box on it. 1 5/8 headers with 2 1/2" exhaust with H pipe and Flowmaster 40 series mufflers. Now it really ran GOOD! I tried to continue using it as my daily driver/work truck, but it was obvious that wasn't going to work much longer. I did get a chance to take it to our local track (Edinburg Speedway) once where the best I could get it to do was a 14.40 at 102mph. By its trap speed, it should have been faster, but it has 3.42 gears, and that was on stock street tires with very little traction. Eventually the trans started going out again, and I was getting tired of the non stop money pit this thing was. I ended up getting another truck, and parked this one under the carport where it sat for the last 5 years, untill yesterday. I can't believe how rusty all the chrome and such under the hood got over the years. In the video below, its running off a gas can, the fuel in the tank is awful!!! I'll be pulling the gas tank as well as the trans here very soon to get her road worthy again. After hearing it run again, I'm very excited to get the rest of the truck back up. Thanks, and here is a video along with a couple pics. Matt https://www.youtube.com/watch?v=LprC_LPKj1c |
09-22-2015, 03:00 PM | #2 |
Re: First start of my 84 C10 383 in over 5 years.
I pulled the fuel tank out this morning, and everything is scrap! This modern ethanol laced fuel is awful. I was expecting varnish, and such, but to see everything completely destroyed is not what I was expecting. (see pics below) The tank brackets really need replaced as well.
The fuel tank, and sender aren't overly expensive, but the brackets are pricey. I guess I better get some parts ordered. Matt |
09-22-2015, 03:52 PM | #3 |
Regarding the brackets, check your local pick and pulls first. Unless the truck has been in the rust belt the brackets should be salvagable. Clean them off with a wire wheel, spray with self-etching primer, finish with cheap black enamel spray paint from Home Depot ($1/can.)
Used brackets are available on Ebay for much less than new aftermarket, and new aftermarket don't have factory captive nuts, so you will have to use loose nut/bolts/lock washers to attach them. It is not easy to get between the frame rail and the tank to attach that loose hardware. Be aware that there are 4 different types of brackets. As I recall, 73-80(?) and 81-87, plus left and right bolt pattern, so that makes 4 choices. Also, there are brackets designed for the full length plastic rock shield which have an extra piece welded to the bottom to accommodate an extra threaded stud to support the full length shield. I would stick with the front shield only style, but the full length style will work on any 81-87. We have had some discussion on sending units. I would buy Delco units if the price isn't too steep. I bought Spectras for my 83 dual tanks and the gas gauge needle bounces, but some say that is due to a cheap aftermarket gauge. When the needle settles down the reading is correct, but it bounces when the truck is moving. I check the following for Delco or OEM parts: www.rockauto.com www.oewarehouse.com www.oehq.com www.gmpartsdirect.com Plus, I always check ebay and Amazon once I have the Delco or OEM part number. |
09-22-2015, 04:03 PM | #4 |
Your truck sure sounds healthy, love the exhaust tone.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
09-22-2015, 08:48 PM | #5 |
09-22-2015, 08:45 PM | #6 | |
Matt |
09-23-2015, 04:17 PM | #7 |
That engine sounds strong and mean...
I know what you mean about the poor fuel today. One of my 1979 C20 tanks has rotted out. CT |
09-24-2015, 07:57 PM | #8 | |
Todays ethanol fuel is just awful. I can't believe how fast it goes bad, and can do alot of damage. Even my lawn equipment, if they sit a couple of months without use, the gas is already bad smelling, and corroding the carburetors. Matt |
09-24-2015, 09:22 PM | #9 |
Sounds good!
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
09-30-2015, 06:46 PM | #10 |
I located a better set of tank brackets at my local U-Pull-It. They were $15 a piece. I got my new Spectra gas tank, and sender. To my surprise the tag said made in Canada. I figured it would be China. I repainted the tank brackets before installing. Its nice to have it back running off its own tank. I had it running off a gas can previously.
I also pulled the valve covers to inpect things, and everything looked top notch. Matt
1984 C10 long bed. Built 383, Lunati VooDoo flat tappet 233/241*(.050) 504/525 lift, Brodix IK200 heads, Edelbrock RPM air gap, Holley 750 DP. 700R4 Trans, with shift kit, and 3000 stall. 3.42 gears. 1993 K2500 ext/LB, 4x4. 3.42's, 4L80E, 6.5 TD, Holset Turbo, Intercooled, modified IP, 4" exhaust |
10-01-2015, 07:19 PM | #11 |
Well, I drove the truck out to my shop today so I can pull the trans. It has no OD, and 3rd is slipping. No doubt the 3-4 clutch pack is toast. However, I had rebuilt a 700r4 spare trans for it long ago, as you can see by the dates on the trans. My spare trans is a mild build. It has a high energy 7 clutch stack up in the 3-4 instead of the factory 6, corvette servo, 500 boost valve, and a Transgo SK700jr shift kit.
The current trans thats toast had the works. Alto Red Eagle clutchs, Koleen steels,Red Eagle band, both 2nd, and 4th billet super servos, 500 boost, .300 reverse boost, and Transgo competition shift kit. After I get my other trans in the truck, I'll open the old one up, and see whats salvageable. Here are a couple pics. Matt
10-02-2015, 07:58 PM | #12 |
Nice work
