Vintage 4x4s
WTB: Lower dipstick guide tube
Does anyone have a spare of the short dipstick tubes that go in the oilpan? Not the main tube but these are the 2" or so ones that press in the bottom of the block and guide the tube in the pan. You have to take the pan off to get at. If someone has one handy I would appreciate it.
Jud
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
Vintage 4x4s
Re: WTB: Lower dipstick guide tube
25 shipped if someone has one.
You can get these at any Chevy dealership for about $15. Part number 3951600. Installs from the top before the upper tube is installed. If your local dealer does not want to get you one go to gmpartsdirect.com for $8 plus $13 shipping.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
So,, what else you got???
![]() Join Date: May 2010
That is correct. Most good dealerships still keep one of these on hand, or will at least order one for you.
Always on the hunt...
![]() Join Date: Sep 2006
You can also try looking up Summit Pn: NAL-3951600 / $12.95 for the OE GM piece. Mel
Vintage 4x4s
Thanks guys, but I don't think that is what i need. I think mine is different since its a 4x4? My upper tube fits tightly in the block by itself so I think the part i need must have been pressed in from the bottom. It definitely isn't as long as the 3951600 part and i believe the 3951600 is a non press fit, correct? There was about an inch or less sticking out of the block (to the inside of pan) and nothing towards the outside when I dropped off bare block at the machine shop. If nothing else, I'll just make a tube on the lathe so it press fits from the bottom i guess. I have a parts 350 at the back of the shed I was thinking about digging out but its from a 2x4 so it may have the same long incorrect tube. Anyone seen a shorter tube that presses in and doesn't protrude to the outside of the block?
I very well could be wrong but I believe that all GM V8 SB engines from the early 60s to at least the mid 90s (1st gen) used the same lower tube and they all slip in from the top, not an interference fit, it has a lip that keeps it from falling out. Maybe ask your machine shop? The upper tube is an interference fit and goes down far enough to hold the lower tube in place.
#8 | |
Vintage 4x4s
