10-07-2005, 08:08 AM | #1 |
Wierd thing happened last night
I took my 83 out for a drive yesterday just to drive it and I didn't go very far, just up the street and back. On the way back I was going about 40-45 and the whole truck just started shaking back and forth. It was scary. It was definately coming from the front end. I stopped and got out to make sure a tire was loose or if something was broke. Didn't see anything. So I got back in and drove it home and it didn't do it again. I am afraid to drive it now. Does anybody know what this could have been?
2003 GMC Sierra 1500 (Camper and Dirtbike Trailer Hauler) 2004 Chevy Trailblazer (Wife's Daily Driver) 1983 Chevy 3/4 ton 4x4 350/TH400 (Sold) 1993 Buick Century (My Daily Driver) |
10-07-2005, 08:12 AM | #2 |
tie rod ends or center link worn out, Or, it could be a broke belt in one of the tires on the front. Look for "bubbles" on the tire, tread that looks like it's seperating, etc.
Kirk |
10-07-2005, 09:15 AM | #3 |
STILL PLAYS WITH TRUX
It could also be a worn out upper and lower ball joint.
Do you know if the front end has ever been rebuilt ? or is it still all original? what ever the answer you should probably rebuild the front end. www.p-s-t.com sells complete kits iv'e used one on an S10 i use to have and the components are top quality stuff. WELL WORTH THE MONEY Last edited by 87 STEPPER; 10-07-2005 at 09:15 AM. |
10-07-2005, 08:56 PM | #4 | |
Street Rod Restoration
ball joints
It's the ball joints
Follow me on Instagram @ hot_rod_shop |
10-07-2005, 10:16 AM | #5 |
You could maybe jack your truck up and put it on jack stands. Then get a long steel pipe. You can stick it under each front, and use it to (pry) up on the bottom of each tire. By applying lots of force like this, you can force the tire to move, pushing and pulling on the ball joints. This would allow you to actually see what front end parts are moving that shouldnt be. Also, you could have someone turn the steering wheel while the tires are on the ground. If you lay under your truck, you could watch the steering components, and it should be pretty obvious if a part of the system is loose or bad(extra movement, clanking...). An idler arm, or pitman arm are common culprets of steering problems. A serious problem with your front end could be pretty dangerous, for yourself and others. I would definately try to get your problem figured out before you do any more driving.
good luck robert
86 Silverado SWB 350/350/3.08 9.7-1 Forged pistons Eagle Rods Eagle Crank Zero Deck Balanced Blueprinted 180cc DART Heads Roller Rockers RPM Intake Demon Carb Flowtech Headers 400HP/400TQ |
10-07-2005, 03:49 PM | #6 |
What Hump?
I'm sorry but I may have missed your introduction post, welcome. How long have you had the truck? Was there any problems with it before? If you just purchased it, did the previous owner do anything to the front like lowering with a drop kit? Also as the previous post broought out jacking up the front and trying to move the wheel from side to side and up and down should give an indication with any front end work needed.
tom
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
