![]() Join Date: Mar 2014
Power steering pump identification?
I've got a power steering pump with a bent pulley. Tried to used a puller from autozone but the puller doesn't fit, and it almost looks like the pulley is threaded on. What pump is this?
Posted via Mobile Device |
Re: Power steering pump identification?
sorry for so many comments. phone isnt working well with the site.
That's a slip fit pulley with a keyway and key. Take the nut off the end and it will slide right off.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
![]() Join Date: Jun 2012
^ What he said..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
CST10 .. thanks for the quick reply - is there a seal around the perimeter of the pump? when I dipped it in the mineral spirits part washer a rubber-like material came out of it.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
There is a large O-ring that seals the pump housing to the outer sheet metal reservoir. The mineral spirit washer fluid will degrade the rubber and render it useless. You will most likely have to replace that o-ring.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
How do you replace it?
![]() Join Date: May 2010
Rock Auto has kits with all the seals you'd need. I'm sure NAPA and others must also. Pretty inexpensive. From the pictures on their website it appears the instructions are included.
You had also asked about pump identification. You have what appears to be an original pump. |
Took the body of it off, the o ring is still there and in good condition. Maybe some oil created a film around the outside of the pump or maybe the last guy put RTV around the outside of it.
Is this something worth working on? Or should I just paint it and throw it back in? |
If the o ring is fine, id paint it and throw it back on.
