Old 10-04-2016, 01:58 PM   #1
bvmayor
Signal Stat Column Mount Turn Signal Question
I am installing a Signal Stat 900 on my 65 GMC 1/2 ton. I have a question about hooking it up to my existing wires. I need to know which wire goes to the Turn Signal Flasher feed. I have all of the other wires figured out....I think
My flasher has two prongs and is in the fuse panel. The Signal Stat has two wires which are supposed to go to the Flasher.....One is for PILOT and one is for LOAD. There are not two existing wires to the Flasher....just one.
Can anyone tell me what I should do with the Signal Stat wires and which one should go to the existing Flasher wire?
Thank You,
Jeff
bvmayor is offline   Reply With Quote
Old 10-04-2016, 09:45 PM   #2
jtrichard
Re: Signal Stat Column Mount Turn Signal Question
This should help you.... As for your question looks like both connect to the one flasher lead
http://www.pacificnorthwestspine.com...-kit-hooks-up/
jtrichard is offline   Reply With Quote
