Old 08-23-2011, 07:29 PM   #1
72BlueGMC
Big Block Distributor won't seat..
heres the deal, I have 454 out of a 85 Suburban I stroked and I am installing in my 72 C10...
I am looking for some advice, I have a 454 out of a 85 suburban that I am turned into a 489 (or I am trying). At this point I am trying to use the stock distributor because I have sunk a lot of money in everything else. During reassemble I have tired to drop in the stock distributor several times but I can't get the last inch to drop.
I feel it engage with the cam it gets very sold at that point and I have tried to turn it to line up with the oil pump shaft MANY times.
What am I doing wrong, surley this isn't a first.....
Charles
1972 GMC C10 Long Bed
489 Stroker/400Turbo
72BlueGMC is offline   Reply With Quote
Old 08-23-2011, 08:17 PM   #2
RandyDandy
Re: Big Block Distributor won't seat..
If you roll the engine over on the starter it should drop the rest of the way in.
RandyDandy is offline   Reply With Quote
Old 08-23-2011, 08:43 PM   #3
72BlueGMC
Right now it is just dead weight, the starter is not on, I have sat it in there and turned it over by hand just a bit and the got real tight so I backed it off. Maybe I will try again tomorrow...
Charles
Old 08-23-2011, 08:55 PM   #4
RandyDandy
IT would be easier if you had the starter on. What i do is hold a slight pressure down on the distributor and have somebody roll the engine over on the starter a few revolutions and it drops right in.
Old 08-23-2011, 09:13 PM   #5
72BlueGMC
Good info I will try it that way this weekend, is it normal to fell very tight when it is trying to go in I guess?
Charles
Old 08-23-2011, 09:44 PM   #6
RandyDandy
I am not sure what you mean about feeling tight, but it will only go down so far untill the oil pump dogs line up with the distributor.You could also call your engine builder and see if you need a different distributor gear for your application. You could also maybe ask a mechanic friend to give you a hand if you know one. Good luck i hope you get it figured out before you get too frustrated.
Old 08-23-2011, 09:53 PM   #7
turp mcspray
turp mcspray's Avatar
The slot in the oil pump needs to line up with the cross pin in the distributor shaft. Like others have stated, if you can turn the engine over, it will drop in. Otherwise pull the dist back out, look down the hole, stick a large screwdriver in the oil pump slot and turn it where it needs to be.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
