05-15-2005, 06:29 PM | #1 |
Alignment pros/heros wanted!
First the backround info: My 74 has been dropped in front w/3" BT spindles & 1 coil removed from the factory V8 springs & a flip kit w/drop shackles out back.
When I dropped it almost 3yrs ago, I replaced all the ball joints, all a-arm bushings, inner/outer tie-rod ends & sleeves, & installed a new idler & pitman arm. It aligned w/o much drama other than my pet peeve of the steering wheel not being 100% perfectly centered. Well, fast forward to the present w/less than 15K miles & both front tires show excessive inside/outside edge treadwear vs. the center tread & the truck pulls to the left like a SOB. The tires were 255/45/18's on 18x8" wheels & I typically ran 32-35psi of air. This weekend, I got some new 245/45/18's (I felt the new size was a better fit for the 8" wheels) & my intention is to get the alignment checked ASAP. Suprisingly, after the new tires were installed the truck doesn't pull @ all; just like after the rebuild. So WTF gives here? I figured maybe the toe was out of adjustment but since it has excessive wear on both inside & outside I'm not sure. What could it be? Professional opinions appreciated.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-15-2005 at 06:30 PM. |
05-15-2005, 06:59 PM | #2 |
Sounds more like a tire pressure problem to me. What were the specs after your origional alignment (camber, toe & caster)
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
05-15-2005, 07:13 PM | #3 | |
05-17-2005, 09:21 AM | #4 |
70 Chevy 3/4t
yep sounds like an UNDER inflation problem to me.
Find a job you love and you'll never have to work a day in your life. 1998 Yamaha V-Star 650 1970 Chevy 3/4t, I6 (rebuilt), 4 speed Kokomo,IN |
05-17-2005, 09:55 AM | #5 |
The 255 tires may have been a little too wide for those 8" rims. The new 245's should be a better fit.
Usually it is caster that causes it to pull to one side. Could also be camber, but with the wear pattern you describe, that does not seem likely.
- Greg |
05-17-2005, 10:23 AM | #6 |
I went yesterday & had the alignment re-checked @ the same shop that originally did it.
The numbers were within spec & actually still extremely close to the original alignment numbers from 2yrs ago which suprised the guy. He went ahead & adjusted the toe to correct the crooked steering wheel but left everything else as is. I'm going to drive it for a month & see how it goes. 454HO, yes the 245's are a better fit for the 8" wheel which is why I switched to the new size. I was keeping tire pressure @ or above 35psi but I'll stick w/the recommended 44psi & see if that works better. Thanks for everyones input. I value other peoples experiences & input.
05-17-2005, 11:22 AM | #7 |
I work at a tire shop, and we see this occasionally. Sometimes it is inflation problems, or one of your tires might have what is called a "radial pull", which causes one of the tires to drag, pulling the vehicle one way or the other. If you swap the tires side to side, it pulls the opposite way.
It is considered a manufacturer's defect, and usually causes uneven wearing due to the fact that both front tires are constantly under stress from the truck trying to drive sideways.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
05-17-2005, 07:58 PM | #8 | |
Judging from the wear patterns, I don't feel the excessive wear caused the separation issue as the rest of the tire was ok & the separation was isolated to the 'bubble-ed' area of the tread.
