Old 11-22-2006, 07:44 PM   #1
Pritchard1970
Rez Power Steering kit HELP PLEASE ASAP
I just got the Rez power steering kit from GMC Pauls and it seems me that it is not fitting right. I have attached some pics to help further explain my situacion and would appreciate anybody's help.....The problem #1- the top right hole is no aligned with solid metal, the pic and explanation in the directions show the bracket and the top hole aligned in a place on the frame that will allow you to drill it out. Not the case for me #2- the bolts included in the kit are not long enough to go through the frame. My frame is a stock 2wd but it is boxed from the factory in the spot were the bolts go through......anybody have this problem? Help please!!!!Thanks for the replies
Pritchard1970 is offline   Reply With Quote
Old 11-22-2006, 11:11 PM   #2
zenish
Re: Rez Power Steering kit HELP PLEASE ASAP
if thats a 1960-62 chevy,cpp sells the correct kit for your truck.that frame is nothing like my 64.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 11-22-2006, 11:47 PM   #3
Pritchard1970
It a 1962 Fleetside....hope to find a solution
Old 11-23-2006, 01:32 AM   #4
slepysal
slepysal's Avatar
Yup, our 60-62 frames are diffirent. Rez list one kit but CPP list a kit for 60-62 pn 6062PSK ( and pn6366PSK for 63-66 )
I would sugest calling REZ up and see what they say .
slepysal is offline   Reply With Quote
Old 11-23-2006, 10:32 AM   #5
Pritchard1970
After I ran into the problem and tried to solve it I cleaned up the manual box and all the associated bolts....it is in great shape and the worst case scenerio is that I reuse my original box.......but I am holding out hope.....what is the full name of the other company I should check out...CPP stands for what? thanks for the help guys
Old 11-23-2006, 11:20 AM   #6
kdevore2
Classic Performance Products http://www.classicperform.com/
kdevore2 is offline   Reply With Quote
Old 11-23-2006, 11:22 PM   #7
zenish
id make pauls give me the right kit.
1964 c10 short step
1962 econoline van
1989 rs camaro
1975 goldwing
Old 11-29-2006, 09:43 PM   #8
slepysal
slepysal's Avatar
Update ? What hapened?
Old 12-01-2006, 11:00 PM   #9
Pritchard1970
I have solved the problem and will post some pics in the next couple of days.....It has been a process but I think it will work out great...
Old 12-21-2006, 04:57 PM   #10
slepysal
slepysal's Avatar
So did it work out ok ?
