05-04-2005, 08:03 AM | #1 |
Keep On Truckin'
Which wire is the "start wire"?
Which wire is the "start" wire on the ignition switch of a '72? It appears to be the purple wire from the wiring diagram but I need to verify.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
05-04-2005, 10:09 AM | #2 |
I can't say right now that it's purple at the switch but it's certainly purple at the starter.
Saskatoon, Saskatchewan Canada |
05-04-2005, 11:35 AM | #3 |
Msgt USAF Ret
My haynes manual shows it to be purple. May I ask why you need to verify?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-04-2005, 02:54 PM | #4 | |
Keep On Truckin'
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... Last edited by mocwon; 05-04-2005 at 02:57 PM. |
05-04-2005, 03:04 PM | #5 |
Lovin' Life in Miss.!
Are you sure the signal needs to be (+)?
I had this here at work, so I scanned it for ya. 12ga purple
The truck... you hear that? No really, you did hear that?!!! Last edited by chickenwing; 05-04-2005 at 03:53 PM. |
05-04-2005, 04:47 PM | #6 |
Keep On Truckin'
The Painless instructions say the "start" wire. I guess I better call them and talk through the instructions. Thanks for the scan!
05-04-2005, 06:29 PM | #7 |
its all about the +6 inches
Instead of splicing, you could cut the plug off the neutral safety switch, (same purple wire) and use femail spaid connectors, and on one of them, you run two wires into the crimp on connector. One being the purple, and one being the ECM wire.
05-05-2005, 11:56 AM | #8 | |
Keep On Truckin'
05-05-2005, 12:08 PM | #9 | |
http://www.americanautowire.com/products/Connectors.cfm
The truck... you hear that? No really, you did hear that?!!! Last edited by chickenwing; 05-05-2005 at 12:09 PM. |
05-04-2005, 10:34 PM | #10 |
Msgt USAF Ret
Why can't you just wire to the s terminal on the solenoid, its the same wire .
