Old 03-29-2005, 06:12 PM   #1
TruckinDaddy
What's that funky smell?
TruckinDaddy's Avatar
Rochester 2G Rebuild
I am at a standstill on rebuilding my carb. The OE carb number tag is no longer attached. The only number I have found on the carb is stamped under the fuel bowl. 7035027. But, this number does not show up as an OE carb number. At least no where I have found.
NAPA needs the OE carb number to make sure I get the right rebuild kit. But this number did not show up in any of thier carb listings. LMC sells a "carb repair kit" for the 2G that is not for specific OE carb numbers. But I don't know if it is a complete rebuild kit, or not.
Any suggestions? Past experiences? I would prefer to try this myself, to gain experience with the truck and to save a little $ for other projects on the beater. But, I might have to go the reman route, (for almost 10 times the cash!),
Mike S
68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck
3 on the tree, 307, No power brakes or steering
Factory Options - HD rear spring and Ammeter/Oil Gauges
My truck blog
My Car Domain page
TruckinDaddy is offline   Reply With Quote
Old 03-30-2005, 01:24 PM   #2
TruckinDaddy
Not that I am begging or anything. But I will cry a little if it helps....
ttt
Mike S
My truck blog
My Car Domain page
Old 04-01-2005, 01:35 AM   #3
jimfulco
My past experience with "remanufactured" carbs has not been very good. A professionally rebuilt original carb is much better, & usually cheaper. Yours seems not to be original, but if it worked well at one time, I'd say get it fixed. A local shop rebuilt my friend's 2G a couple of years ago for under $100, including parts (& he had to chase down the parts).
jimfulco is offline   Reply With Quote
Old 04-01-2005, 10:19 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
that IS a good rochester #. (for a '73)
starting in '79 the numbers began with a "1" making them 8 digits. prior they were 7 digits. try another parts store, the kits are pretty much the same wherevere you go.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 04-01-2005, 10:29 AM   #5
TruckinDaddy
Originally Posted by 68C15
that IS a good rochester #. (for a 73)
Cool, Thanks for the info. I'll be giving it a shot this weekend or next.
Mike S
My truck blog
My Car Domain page
Old 04-01-2005, 01:25 PM   #6
redhead69
fugedaboutit
redhead69's Avatar
I know there is 2 different kits... one for the 2g's and a different one for the 2gv's.. on the instructions there should be pics of the different carbs they work on... the gv's diaphram is at an angle and needs a different kit. I dont know what the differences are but just went thru this trying to find a rebuild kit for my 69 307.. ebay' got new ones for cheap (not rebuilt) I will get the sellers name for ya
redhead69 is offline   Reply With Quote
Old 04-01-2005, 01:30 PM   #7
redhead69
fugedaboutit
redhead69's Avatar
should be able to get this for pretty cheap.. Item number: 7965631809.. ebay
