Old 03-24-2010, 07:59 PM   #1
BarnabyHooge
Seat Belt Install...What am I missing?
I've got the bolt for the top anchor, the bolt for the short side in the middle of the bench, and the bolt for the retractor by the door. Where does the fixed point of the retractor side go?
I just got this truck and the wife won't go for a ride iuntil they're installed. I was hoping my first post would be the pics and an intro, but that will have to wiat!!!!
BarnabyHooge is offline   Reply With Quote
Old 03-24-2010, 08:41 PM   #2
BarnabyHooge
Re: Seat Belt Install...What am I missing?
I'm thinking it just gets attached to the same bolt as the retractor but the package contains a warning re: using the same bolt on one "lap belt".
Old 03-24-2010, 08:51 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
On my 3 point belts, the retractor is bolted to the floor by the door. I used the factory bolt, but had to open the mount up a little with a Dremel. Your belts may be different though. Welcome to the Board BTW.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-24-2010, 09:00 PM   #4
BarnabyHooge
Thanks. I've got that down there, but there's one more point that needs to be attached. Do two points get attached by the door? The retractor assembly and the other anchor bracket?
Retractor is attached at the floor and runs up through the top shoulder anchor, then back down to....
Old 03-24-2010, 09:08 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
I just went out and looked at mine. I have both parts of the shoulder part of the belt anchored with the factory bolt at the floor, and the pivot anchor at the ceiling.
Beat it to fit,
Old 03-24-2010, 09:03 PM   #6
Sinister
Between Trucks...
Sinister's Avatar
A pic of what you're working with would help. Mine are 3 point belts. Retractor at the floor by the door, pivot anchor at the ceiling, latch through the seat at the floor. 3 bolts for mine. The shoulder part should be a loop, maybe that extra anchor you have bolts down with the retractor.
Beat it to fit,
Old 03-24-2010, 09:05 PM   #7
my67chevytruck
Under Construction
my67chevytruck's Avatar
any pics? retractor should be by door, then up to the shoulder mount, the buckle (male end) should cross the shoulder and plug into the female end in the middle of the truck, you will have two belts on each of the inside ( middle) bolts for the middle seat belt.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-24-2010, 09:10 PM   #8
BarnabyHooge
The metal piece closest to the retractor is what I'm confused about. I'm assuming they get bolted together, but I want to make sure before I do it.
THANKS!
Old 03-24-2010, 09:26 PM   #9
Sinister
Between Trucks...
Sinister's Avatar
THANKS!
Looks like the same belts I have. That metal piece gets bolted under the retractor. I used the factory bolts and had to open the mounting point on the retractor a hair.
Beat it to fit,
Old 03-24-2010, 09:39 PM   #10
BarnabyHooge
Alright, I'll bolt it under the bracket. I'll know if its not right when my face hits the wheel....
Thanks again.
Old 03-24-2010, 09:55 PM   #11
Sinister
Between Trucks...
Sinister's Avatar
That's how mine are bolted up, you'll be alright.
Beat it to fit,
Old 03-24-2010, 10:31 PM   #12
BarnabyHooge
All set. The passenger side had room for the L bracket mount, but the driver side didn't. I had to bolt the retractor laying flat directly to the cab. I'll post pictures when I get them uploaded.
