What wire go to the front turn signals
OK here goes the PO put a 72 grill on a 69 truck C-10. I put the right grill back on and now I have to wire the turn signals and I have only one wire going to the turn signal but the light has two wires I need help......
Thanks in advance Paul |
Re: What wire go to the front turn signals
driver side should be a light blue and a brown and pass side dark blue and brown if its the same as 71trucks// the browns are running light and blues are signals
If they didn't change the connections in 72 they should plug right in. I have a 71 with 69 lights and the factory plugs worked great.
Sounds like the PO hacked up the wiring pretty good. Go with cdowns suggestions for redoing it. Last edited by 71tahoe; 10-16-2007 at 10:04 PM. |
Thanks for all the help I will try and search the wire down after work tomarrow....
Thanks Paul |
