Dumbest question of all time!
My 78c10 350 runs great but as I was working on lining up my body panels w/my hood off I noticed that the plug wires going to my distributer were a jumbled mess.
I think they may be miss timed (I've seen a small block run on 2 cylinders) I checked my Chiltons manual for a firing order & concluded that if I don't know which cylinder represents which # a firing order does me no good. Can somebody just tell me which cylinder is which? A diagram would be a big help. Thanks. |
Right turn Clyde
Re: Dumbest question of all time!
Driver side of the block front to back is 1357 and passenger side is 2468.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
Droppin' It Like It's Hot!
8-----7
6-----5 4-----3 2-----1 Front Does that help? ![]()
Robert
Life Member RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09 1969 ![]() Norwood, MO 2007 Big Sandy, TN 2008 Had nothing to do with the forklift! Kirkwood, MO (Midwest Meet 2009) Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014 SUPPORT THE SITE HERE! |
Arrived on a Pale Horse
#1 on the cap is the second post clockwise toward the front of the engine from where the wires attach.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW Last edited by babyJay; 06-25-2007 at 12:54 PM. |
What did you say...
![]() But seriously, to maybe add stupidity to this thread, does it matter which one you plug the #1 plug wire to as long as they are in the proper firing order?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 06-25-2007 at 01:12 PM. Reason: To be a good boy |
HA HA
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW Last edited by babyJay; 06-25-2007 at 01:53 PM. |
Right turn Clyde
The firing order on the cap can start anywhere. Get #1 on TDC on compression stroke. Pull the distributor cap off and look at where the rotor is pointing. That will show where the firing order will start. It starts clockwise around the distributor cap.
1962 C-10
On an HEI distributor, #1 is usually pointing around 4 or 5 o'clock, then it goes around clockwise 1-8-4-3-6-5-7-2.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
