07-10-2007, 10:49 PM | #1 |
grinding gears
Got a 4spd trans in my truck with the granny gear. It will grind gears if i try to put it in low or reverse but the others dont grind. if i shift into first then put it in low or reverse they dont grind. anybody know how to fix this?
Its no disgrace being poor. Its just inconvenient. |
07-10-2007, 11:19 PM | #2 |
Re: grinding gears
I don't think the granny gear or reverse is synchronized, but I may be wrong.
07-10-2007, 11:26 PM | #3 |
Happy to be here
Re: grinding gears
You are correct.
07-11-2007, 04:26 AM | #4 |
Re: grinding gears
I only used to ever grind trying to shift whilst moving with mine. From a stop reverse was smooth and dead low was shifted with a very small clunk. It was however rebuilt about a year before I brought it by the P.O. I think that clutch adjustment makes a huge difference as well. The gearbox in the C30 grinds every gear even with the new clutch in it and adjusted, its just plain worn out after 28 years and i'm guessing bad driving by the P.O.
07-11-2007, 11:01 AM | #5 |
Re: grinding gears
shouldnt double clutching keep them from grinding?
07-11-2007, 12:00 PM | #6 |
On a budget like Fred Sanford
Re: grinding gears
Not necessarily. While sitting still, shift into high gear (3rd for you) before shifting into L or reverse. That should minimize the grinding. Shifting gears with no syncros takes some getting used to, gotta get used to the "feel" of where the gears are.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
07-11-2007, 06:00 PM | #7 |
THE VILLIAGE IDIOT
Re: grinding gears
my clutch has less than 20,ooo on it..and if sitting still it will grind granny and reverse....but if i shift it into neutral,,then shove the clutch back in,,it will shift smooth..
billy
honestly honey,,i have no idea how that truck got here. |
07-11-2007, 09:28 PM | #8 |
Professional Grade
Re: grinding gears
Just make sure that the truck is stopped, and that you give the transmission a few moments to stop spinning after you release the clutch. If it keeps spinning, then you need to adjust your clutch a bit so the disk totally disengages
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
