Drop spindles for a 86 C20 4X2 Silverado
Gentlemen I'm ready to order my parts for my static drop on my 1986 C20 Chevy Silverado, 5.7L, 700r4,4X2, Standard Cab, Brown and tan in color. My Vin. has a L in it.
I have contacted several vendors and I'm have trouble finding drop spindles for this C20, 8 lug truck. I have done the search and see I need to use C30 spindles I think ??. If I have to change out brake rotors that would be OK because mine are in need of replacement.(very thin) So Help, Thank you Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
Re: Drop spindles for a 86 C20 4X2 Silverado
Get C30 drop spindles, and swap out your calipers with new brake lines.
Everything else is the same. |
Or you can buy C20 drop spindles from POL and bolt everything up.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#5 | |
Order my parts today from Western Chassis. Front drop spindles, drop springs, 4 drop shocks, rear hanger kit. I already had a new shackles installed. I'll show the goodies as they arrive. And before & after pics.
These parts where not cheap, anyone wanting to drop a C20. Make sure you have your penny's saved. Ken
Hey Ken - how did you get on with Western Chassis..?
I was recommended POL for the drop spindles for my 77 C20, but would be good to know if there's an alternative. Thanks
Barney, in the UK 1962 Chevy C20 1974 Ford Econoline 1987 Peugeot 205 GTi 1991 Peugeot 205 GTi |
#8 | |
Ken
Drop shocks wouldn't be needed with spindles alone, would they?
What C30 spindles would work well? If I end up doing a drop sometime I wonder whether it's worth converting to get better brakes (I'm putting discs on the rear).
1973 C20, 350/350 |
