Old 12-17-2015, 07:28 PM   #1
Mthumphrey
Mthumphrey's Avatar
Chevy 250 Running Dual Exhaust
Anyone have pictures how they have run the dual exhaust on a 250? I have Clifford shorties and want to run the exhaust in front of the rear wells. Any pictures would be great! Thanks!
Mthumphrey is offline   Reply With Quote
Old 12-17-2015, 07:45 PM   #2
blown240
blown240's Avatar
Re: Chevy 250 Running Dual Exhaust
I don't have a 6, but I am running my exhaust on the outside of the frame rails. Then they go under the frame by the trans cross member...
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 12-18-2015, 11:59 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Are you asking about routing the exhaust tubing from the collector, or just the tail pipe position in front of the rear tire? You will have to route some of the tubing to the outside of the frame rails at some point. I snaked mine under the front frame rise, which allowed me to route the rest of the exhaust to the outside of the frame rails.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-18-2015, 10:58 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
I'll get some pictures of my old setup when I get home. You could probably have a local shop do it for cheaper then you could.
Old 12-21-2015, 07:11 PM   #5
Mthumphrey
Mthumphrey's Avatar
Cool. Thanks!!!
