Old 08-09-2007, 09:06 PM   #1
brawley
Easy Does It
brawley's Avatar
speedo cable
I recently unpluged my speedometer cable to take out my instrument cluster. Now I cannot get the cable to go back on, it will only push so far, but not enough to screw the nut to tighten? What am I doing wrong?
brawley is offline   Reply With Quote
Old 08-09-2007, 09:26 PM   #2
LAFNATU
LAFNATU's Avatar
Re: speedo cable
I had the same problem, it was like it wasent lineing up. I just kept messing with it and it finally went. I know this dosent really answer your question, but i thought it would help....
LAFNATU is offline   Reply With Quote
Old 08-09-2007, 10:30 PM   #3
mateo1279
mateo1279's Avatar
Re: speedo cable
I was having that same problem awhile back. I ended up replacing the cable abd it went on with out a problem. I went to napa to get the cable, if you do, get the shorter size.... I now have too much cable under my truck and had to do some creative routing....
1962 Chevy Fleetside
283/TH350
mateo1279 is offline   Reply With Quote
Old 08-13-2007, 10:44 PM   #4
brawley
Easy Does It
brawley's Avatar
Re: speedo cable
I finally got it back in -I had to twist the small wire back down into the tube,and it slid back on.thanks
