Blinker Both Flash with Running lights and Head lights off
Question I finally got a new wiring harness installed from a guy on this forum (HID Harness).. But I noticed and I am not sure it was doing it before but Now if I turn my blinkers on both flash like the flashers are on.. Not if I turn my running light or head lights on they work as normal.. Did I do something wrong? I dont think this was a issue before but I could be wrong
1984 GMC 1500 Swb LS SWAP 6.0 4l80e - Ongoing Restoration 2013 Silverado Rocky Ridge - Daily Driver Squarebodynation.com Facebook: SBN |
Re: Blinker Both Flash with Running lights and Head lights off
I was just told that the LED bulbs I put in the Blinkers might be causing the issue.. Any idea how to use the LED and not have this issue?
I have the same issue and have replaced nothing. When I have headlights off they both blink when I turn on the left blinker and right on by its self. And when I hit the brake lights running lights come on. Its all jacked up. So I hope someone can help us both.
Usually when strange things like this take place is because of a bad grounds . The power is trying to find a path when the ground is missing , I would find all your ground sources and remove and clean them and see if the condition goes away .
Mine wasnt that bad when turn the Head lights on the left indicater stayed on. checked cleaned grounds it was still on. Few months later notice left park light out pulled the socket out and it was on wiggled wires off on replaced socket. Low and behold that also took care of the indicater problem also.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
Gas Monkey Garage had LED bulbs do the same thing on their Knight Rider project. Swapped back to regular bulbs and no issues. Usually a ground issue as stated and some diodes don't pass power to ground properly.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
![]() Join Date: Oct 2014
I've only had my truck for a short time, so I don't believe I had an issue until I started swapping out my bulbs to LEDS. Mine was doing the exact same thing. One of my parking light sockets was bad, so I replaced both. That took care of that problem, but I'm still having weird things going on with my lights. Like now, when I put my foot on the brake, all the parking lights come on-even the turn signals both light up on the dash. It's driving me insane!!! I'm about to switch back to the regular bulbs and see if all the problems go away.
The guy at AutoZone was saying that the LEDS will cause issues especially with the blinker action. I didn't have that issue, but I still put that LED relay in the relay box. Maybe he was right, the LEDS are just causing everything to not work properly. If anyone has any suggestions, I'm open too any and all help. |
Changed all my bulbs back to the regular bulbs (I got all new ones), and low & behold everything works as it should. So I guess the LEDS were the issue
#9 | |
![]() Join Date: Mar 2015
has anyone tried to individually ground each one? like the cab lights are grounded? i think i might try this first before scrapping all these bulbs (yes i have the LED specific flashers for the blinker and hazards) |
I was told that if I would have put load resistors on, they would have been fine. I just didn't want to mess with it anymore.
just to close this out, ive tried load resistors, LED specific flashers and independent grounds at each location and the bleed through is too much.
i had to go back to the incandescent bulbs in the flashers and the tail lights. just an FYI. |
I too, had to go back to the regular bulbs. And then everything was fine.
