Low Oil Pressure?
Well what is proper oil pressure for a 350 to be running? At idle I got around 7 and at wot I have between 25 and 30. If this is low for these engines, what should they be running at? And what would cause low oil pressure?
Thanks, Chris |
Re: Low Oil Pressure?
my 305 when cold on startup runs 60 lbs of pressure. When on the freeway at about 75mph its about 38 lbs. After hours of driving and at idle, its at 30 lbs. After it is warmed up, as in oil at 180 degrees, and i floor it from idles while in park, it goes from 30 to about 52-55 lbs in that range. this is a bone stock rebuilt 305 v8 with a flowmaster with 24000 miles on it.
the pollock
have you pulled your oil press regulator and checked for crap in it? if its gunky it wont read well..
or hey have you replaced it ever? it's about 15-20 bucks for a new one..
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
Well I couldnt tell ya on that one. I know nothing about chevys. Where on the motor would that be? Oh the stock electrical gauge is no longer hooked up. I have an aftermarket mechincal one. If that has anything to do with it.
the pollock
should be in the same place look in the back it'll be the hole to the side of your distributor
it wil be at "behind" your intake manifold and will have a brass adapter to a sensor and single wire (usually) some after market pressure gauges have little sensors but they are still in the same place.. so good luck..
![]() Join Date: Oct 2006
I get about 40 at idle on my 350 my truck is a 79. I also ran in a separate mechanical oil gauge. Check to see if the line to gauge is clear. How many miles on the engine ?
Ok I know where it is now. Miles on the motor, I couldnt tell ya. When I bought the truck, it had a six cylinder in it but wouldnt run. So I bought this 350 and was told that it was a good motor. Well....I had to change the head gaskets, timing change and gears so far. So Im about ready to just pull it and put something else in. Actually, I still need a carb to get it running good. So Im kinda scared about this low oil pressure..lol. But I think this motor is gonna need a rebuild anyway, its getting a little bit of blowby, so Idk. Cant decide on what to do.
Thanks, Chris |
the pollock
http://www.autozone.com/R,431903/veh...ductDetail.htm
i think it's kinda funny .. i ased a few days ago where an oil leak could b ecoming from.. it led me to that part.. and now im passing on alllllllll the links ot you guys.. timing is funny..
also low on oil also does this when at idle it fluxuates like a tach and when you gas it, its up around normal check that and if your oil is good you have sometyhing clogging it or the oil pump going bad
http://67-72chevytrucks.com/vboard/group.php?groupid=37 73 C10 Fleetside ![]() If it ain't a Chevy it's foreign ![]() http://hotridesmag.com/ |
Ok Thanks for that I will check into that. I do know it needs an oil change.
