Old 03-29-2016, 09:54 PM   #1
Rod Run
Rod Run's Avatar
Vintage Air & smooth firewall question
The big brown truck dropped off my system today. I got my condenser and everything outside installed, but then I ran into a roadblock.
I mounted all the brackets on my evaporator and now have a question.
The instructions say to use 2 bolts through holes in the firewall, to mount the rear bracket. My firewall is smoothed, so I have no holes. This means I have no way to mount the bracket, or even locate the evaporator. What did you all do, that have shaved firewalls?
Thank you
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 03-30-2016, 01:36 AM   #2
badherb
badherb's Avatar
Re: Vintage Air & smooth firewall question
maybe try this
http://www.mscdirect.com/browse/tn/H...navid=12102936
1960 SWB “Pops”
If you won't support our troops then stand in front of them!
badherb is offline   Reply With Quote
Old 03-30-2016, 02:37 AM   #3
Frugalmeyer
I ordered my Vintage Air kit today and plan on smoothing my firewall. I am going to use the Vintage Air template to locate the bolt locations, drill the holes through the firewall, put the bolts against the holes from the inside with the head side facing the firewall, and spot weld through the hole onto the bolt head. Or you can spot weld the side of the bolt heads to the firewall from the inside. If your firewall is painted then those ideas probably will not work.
Frugalmeyer is offline   Reply With Quote
Old 03-30-2016, 07:37 AM   #4
Rod Run
Rod Run's Avatar
My firewall is already smooth, so I would be guessing on template location.
You also might want to rethink your idea. The bolts twist INTO the threaded support bracket, so a stationary bolt won't do you any good. Once you get the kit, you will see what I mean.
Old 03-30-2016, 08:30 AM   #5
Hart_Rod
Hart_Rod's Avatar
Post pictures of your firewall...
Hart_Rod is offline   Reply With Quote
Old 03-30-2016, 09:23 AM   #6
Rod Run
Rod Run's Avatar
It ain't pretty
Just waiting for the wetblaster to get here and strip the cab and inner fenders. Should be done in a couple/few hours. Then it's on to final bodywork
Old 03-30-2016, 07:30 AM   #7
Rod Run
Rod Run's Avatar
Originally Posted by badherb View Post
those won't really help the situation
Old 03-30-2016, 04:48 PM   #8
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
It's really simple to do.. Place your metal plate that comes from V/A in place on the inside of the firewall just using it to locate your two mounting holes. The directions tell you which two to use.. Mark the holes and pull the panel off. Take two 5/16 X1" bolts and weld them in your marked locations.. On your bracket that bolts to the vintage air unit drill the threaded holes out to 3/8".. Then slide the unit in on the welded in studs and use nuts or locking nuts to secure the unit.. Then use the provided sheet metal screw to attach the top bracket the inner cowl..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 03-31-2016, 11:10 AM   #9
Rod Run
Rod Run's Avatar
Thanks Kyle. I actually bought this kit off of Laid Back. it's awesome to know that you guys can help out on this end too
I'm heading back out to the shop right now to take care of this. THANK YOU very much!!
Old 04-01-2016, 02:45 PM   #10
biketopia
Never installed one of these units but reading what everyone was saying, this idea was exactly what I was going to suggest.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 03-31-2016, 07:35 PM   #11
screaminchevypickup
Laid Back
No problem and thank you for the business..
72 chevy swb
Kyle
Old 04-01-2016, 08:37 AM   #12
MattPSU
MattPSU's Avatar
I was in the same boat. I had shaved and painted my firewall before I bought & installed my vintage air kit. I don't have any pictures, but I made a bracket that hangs down. Two bolts run through the inside of the cowl, pointing down to hold the bracket in place. So far so good.
Good Luck!
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 04-01-2016, 01:43 PM   #13
Rod Run
Rod Run's Avatar
Just mocked it up as described and it went fine. I still got to take it back down, to install my lines and see exactly where they are going to run. I bought the longer hose kit, that way I could run them out the firsewall way over toward the fender
Old 04-01-2016, 06:47 PM   #14
Raleighswb
Ran my lines out the fresh air vent in the kick panel then over the inner fender to the front you only see the lines from the front of the inner fender naturally my picture is upside down but maybe this will give you another option good luck used a vintage air bulkhead
Raleighswb is offline   Reply With Quote
Old 04-01-2016, 09:41 PM   #15
Rod Run
Rod Run's Avatar
You must have uploaded the wrong picture, because there are no inner fender wells in this picture. Heck... There aren't even any lines coming out of the firewall or a bulkhead
Old 04-01-2016, 11:42 PM   #16
Zeroman
Zeroman's Avatar
Hey Rod Run, any way you could post up pics and dimensions for the bolt placement?
I am going to have to do the same thing, but my paint will be done way before I can take delivery on my Vintage Air System.
Thanks if you can.
Zeroman is offline   Reply With Quote
Old 04-03-2016, 07:09 PM   #17
Raleighswb
Truck is apart lines run out bottom of cowl lay on top of inner fender,they are hidden behind the area where the inner fender bolts to the fender here is the area at the bottom of the cowl where the bulkhead is located lines go from the unit through the fresh air vent---then you fab up something to close up that area around the lines hope this helps I ordered all my hose ends from summit
Old 04-05-2016, 04:43 PM   #18
trkfrk
trkfrk's Avatar
Subscribed. Good thread, I am ordering my unit next week. My firewall is shaved/painted.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 04-05-2016, 04:48 PM   #19
1moretoy
Here is a picture of my firewall. I'll take a picture later of how I mounted my evaporator. I'm using a unit from classic auto air but it's the same concept.
1moretoy is offline   Reply With Quote
Old 06-07-2018, 11:47 AM   #20
crakarjax
crakarjax's Avatar
Ah, interesting approach! The thing I mainly can't wrap my head around is getting the plumbing into the fresh air vent without creating interference in the passenger footwell but your approach seems to bypass that concern.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 11-21-2018, 10:24 PM   #21
57larry
does anybody have a template of the AC firewall hole. my firewall is bare & I'd like to cover the hole with a plate.
thanks, Larry
57larry is offline   Reply With Quote
