63 chevy drums
I am trying to pull the rear drums on my 63 and i am having no luck. When i pull on the drum, the lugs come with it almost like they are atached. There is about a 1/4 inch of play in them. I tried to back off the adjuster but that didnt seem to work. Is there something that i am missing, or do i have to remove the axle to get the drums off?
63 chevy 350 crate th350 silverado seats american autowire harness |
C10 now is a GMC
I had a bare of a time getting the rear ones off on my '62 myself.
![]() The rear cables on mine ended up being froze. ![]() Those are the only things I can think of at the moment, if I can remember anymore I post them. ![]() David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
Sounds like you ve backed off the adjusters, check that emergency brake is relaxed. It s common for these drums to get stuck or rust to the axle hub for it is a close fit to begin with. Have had the same problem many times. A slide hammer hooked to the edge of the drum works great at removing stubborn drums and no,,,,,,the axles do not have to be removed. Jim. also note that there will be a small amount of axle side movement due to a small amount of clearance with the axle c clips and spider gear/carrier retainer pin.
Squizzle,
Are you saying that your lugs move 1/4 inch when you pull onthe drum? That's VERY bad! Time to pull the back off of the pumpkin and see if stuff is moving around. There should be essentially ZERO movement in the axle shaft. That being said, the best thing I've found to separate a reluctant drum from the axle is a BFH. Usually giving it a couple of whacks is all that it needs. Brian |
Re: 63 chevy drums
I ran into the same problem on my '62. The quickest way I found to get them off was with a torch. Just run the torch around the drum where it meets the axle for about 5-10 seconds and then give it a pry, should pop right off!
