Old 03-26-2012, 07:14 PM   #1
Shaun1162
Shaun1162's Avatar
Speedometer Gear Reduction Box
So I'm planning on swapping the rearend gears in my C30, and want to know what to do about the speedometer...
Currently the truck has 5.14's, but I'm planning on going to 4.10's.
Can I find a different gear-reduction box that fits on my SM456, or a different gear that goes on the inside of the transmission?
Any help is appreciated, thanks!
- 2010 Silverado
- 1984 Chevy M1028 (K-30)
- 1969 Chevy C-30
- 1933 Ford Stock Car
Shaun1162 is offline   Reply With Quote
Old 03-26-2012, 08:13 PM   #2
48richard
48richard's Avatar
Re: Speedometer Gear Reduction Box
Changing the gears in the transmission is pretty simple. You may be lucky and just be able to change the gear that the speedo cable connects to, otherwise you have to remove the tailshaft housing from the transmission and change the gear in there, but I did the whole job in about an hour and a half.
http://www.transmissioncenter.net/sp...n_______va.htm
has all the information you will need about what gears to buy, and if you're lucky (I was) your local Chevy dealer will have them in stock.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 03-26-2012, 08:21 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
The guys and gals with speedometer problems from swapping transmissions and rear ends have another choice also...As explained in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=421745
LockDoc
Leon
Old 03-26-2012, 08:55 PM   #4
Fldawg
Fldawg's Avatar
Changing the gear where the speedometer cable goes will only change it about 2 to 3 mph, changing the gear in the tailshaft will get you closer. Mine was so far off i used a
speedometer adapter that you find on big truck applicationsgot it dead on with that
Fldawg is offline   Reply With Quote
Old 03-26-2012, 09:35 PM   #5
Shaun1162
Shaun1162's Avatar
I'll definately have to look into that... Hopefully they have the metal gears for the SM465
LockDoc
Very cool idea, however I've got a factory tach, and kind of like things to be stock, but still what a great idea!
That kind of how mine is right now... It's got one of those box adapters that comes off of the transmission. Hoping I can just find one of those with the right gears..
- 2010 Silverado
- 1969 Chevy C-30
Old 03-26-2012, 09:37 PM   #6
geezer#99
geezer#99's Avatar
Here's a link to the easiest way.
http://www.ebay.com/itm/Speedometer-...a9a888&vxp=mtr
geezer#99 is online now   Reply With Quote
Old 03-30-2012, 10:03 AM   #7
Shaun1162
Shaun1162's Avatar
Originally Posted by geezer#99 View Post
Thanks, looks to be just what I needed... Didn't know they made those brand new anymore
- 2010 Silverado
- 1969 Chevy C-30
Old 03-30-2012, 09:21 PM   #8
LockDoc
LockDoc's Avatar
They are listed in the first link that 48richard posted also.
LockDoc
Leon
Old 03-31-2012, 08:09 AM   #9
Shaun1162
Shaun1162's Avatar
LockDoc
Yep, my bad, guess I just scrolled over the section on the adapters a little too fast
- 2010 Silverado
- 1969 Chevy C-30
