Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 09-22-2024, 03:11 PM   #1
RonWT
Active Member
RonWT's Avatar
Hood hinges on a 69 c10
Folks, I have found a couple of sets (used) of hood hinges that are both better than mine. I have installed both sets, and it's better but I can't get the rear of the hood to sit flush with the cowling. Are the aluminum hinges the way to go? Or is there a trick with the OEM style hinges? I have tried the full range of adjustments on the rear bolts, but still haven't got them to sit low enough to be flush.
Thanks,
RonWT
RonWT is offline   Reply With Quote
Old 09-23-2024, 12:01 AM   #2
Hidesertchevy
Re: Hood hinges on a 69 c10
Following
Hidesertchevy is offline   Reply With Quote
Old 09-24-2024, 12:03 PM   #3
A1971Blazer
A1971Blazer's Avatar
Are you able to push it down in to place after it's closed?
Mine was the same way, I could push both sides down and it would line up.
I got new hinges and that fixed it.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 09-24-2024, 03:51 PM   #4
RonWT
Active Member
RonWT's Avatar
I can push it down, but it will not stay.
Old 09-30-2024, 09:08 PM   #5
hugger6933
Any slot left loosen and push up on the front of the hood. That is the normal adjustment for that condition. Jim
hugger6933 is offline   Reply With Quote
Old 10-03-2024, 12:27 PM   #6
MySons68C20
MySons68C20's Avatar
http://www.67-72chevytrucks.com/vboa...d.php?t=319778
https://67-72chevytrucks.com/vboard/...d.php?t=851996
I like the 2nd link better from PJ with the pics.
I hope this helps!
MySons68C20 is offline   Reply With Quote
