C10 Back half an 26's
I need some help I want to go with 26's but I don't have the wheels how would I figure out how to set up everything on the back half with out the wheels
Posted via Mobile Device |
Square
Re: C10 Back half an 26's
Just figure out the overall height of the wheel and then make the back half a couple inches higher than the center to clear the axle. also, what year c10? You might need to narrow the axle with 26s, and they might also sit higher than the bed if you plan on body dropping it.
Squarebody Syndicate |
It's 68 short bed
We talking 26 inch rim or 26 inch tire size?Basicly figure out how tall of a tire will be used and cut out circles in plywood drill out your bolt pattern and use them as mack up wheels.
26 inch rims
Tire size is what matters. Determine your tire size and build your notch accordingly. Also consider the width and backspacing of your wheel to determine width of the frame between the tires.
![]() Join Date: Mar 2012
I assume you would be running a 275/25r26? That's what my friend has on the back of his Suburban. It's 31.4" diameter. Big tire but still looks like a rubber band on the wheel.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
