10-30-2012, 05:50 PM | #1 |
what size rims for 67
i know the 67 rearends are shorter than the 69-72s what size backspacing do i need i would like to run 20x10s
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am. oldno7 |
10-30-2012, 06:03 PM | #2 |
67-72 parts collector,…
Re: what size rims for 67
Stock suspension?
Static Dropped? Bagged?
10-30-2012, 06:24 PM | #3 |
^^^^^ Yep, those are the things we need to know. If it's static dropped, how much?
10-30-2012, 09:35 PM | #4 |
Also if it's a fleetside or stepside.
10-30-2012, 09:47 PM | #5 |
Old Skool Club
Maybe this'll help: My '69 is static-dropped 2.5/4.0. The rearend width is the same from '60 thru '69. I run 15x10's on the rear, with a 5-inch backspace. The tires are 275-60x15's. You can find the diameter of this tire on various websites and compare that diameter to the diameter of the tires you intend to run on those wheels you like. I have a fleetside and have never had any issues with the tire contacting the inside of the wheel opening.....
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
10-31-2012, 05:51 PM | #6 |
its a 4-6 drop spring and a fleetside
10-31-2012, 05:54 PM | #7 |
If you are looking for 20's, then a 20x8.5 will be good with a backspace of 5.25" - 5.5". Out back a 20x10 with 4.75" backspacing.
What diameter are you wanting? Were you in search for a custom built wheel or ???? |
