Got Mud?
Dash lights screwd up...
Dan Got mud? |
Professional Grade
Check the connection back behind the dash, just look up from underneith your seat, and you'll see what I mean
![]() If you need pics, I'll be glad to provide some for you tommorow afternoon. Sometimes that connection will wiggle loose, or maybe something is shorting out behind there.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Got Mud?
Yea pics are always nice!
Dan Got mud? |
Got Mud?
Im bringing this back from the dead becasue its still doing it....any more help??
Dan Got mud? |
North Coast, baby!
I can tell you that my gauges would go nuts like that if the entire housing was not setting in exactly where it was supposed to go. If you take the dash bezel off and then try to adjust the placement of the entire gauge housing this might help. Also the printed circuit overlay on the back could be detached or grounding out somewhere. Good luck.
Brad 79 Scottsdale C20 ![]() 350/350 3.73's Still running full CA smog gear! ![]() |
Got Mud?
Yea i think its a ground prob but dont no were to start looking??
Dan Got mud? |
On mine there is a sheet metal ground - 6 spade posts riveted to sheet metal above the parking brake pedal. If you have a/c you will need a mirror and flashlight to locate. Like all others have suggested remove the guage cluster and check all connections there and the printed circuit connectors. Remove the gas guage and clean the connections. I think there is a resistor between the posts.
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock http://www.oplnk.net/~spirit/K5front.jpg |
Got Mud?
I ve done all that (taking the cluster out and cleaning)..
Dan Got mud? |
