BIG CHEVY 3600 LONGBOX
Looking for answers on cooling fans
I had planned on using my mechanical fan but my 350 sits too close to the radiator. That means I'll need a fan. It's a Walker and is 20 inches wide. I was figuring on a single fan. Can anyone give me some suggestions as to what fan and assorted attachments and where to get them. I should have already researched this after 4 years building this 51 but I had not thought I would need it.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
Re: Looking for answers on cooling fans
Are you asking about an electric fan? If so, look for a F@rd Taurus fan (with a V6, 2 speed) it pushes more CFM's than a lot of high $ aftermarket fans. They can be had for little on Ebay or pull-your-part places. I have one now on my 53. I've used them on trail rigs in the past with great luck. I think I have a pic of my setup on my 53 build. If your looking for a mechanical fan please disregard and carry on.
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
Are you talking about a 6 volt fan? My truck is 12 volt.
No, I'm talking about a 12 volt fan out of a v6 engine F@rd Taurus. The fan is a 2 speed. Awesome fans IMHO.
Sarge,
What year range of Tarus? Will it cool a 350 sbc,330 horse?
Spanked once
![]() Join Date: Oct 2006
I had to move my radiator forward ,its a 3 core and change the mounting brackets on the fan and radiator. It does not ty-rap to the radiator. Mine is a 300 hp with air. Just showing you how close it is.
The ole 350 budget build. |
I used a v6 mustang electric fan .I had to chop down the factory fan shroud and fab up my own in faberglass, works great pulls a ton of air too.cools my 5.3 no prob.
You'd be looking for something like this. Stay away from the duel setup. I've had great luck with these. Do a google search on the fan. Guy's use them on all kinds of rigs, make sure it comes with the connector.
http://cgi.ebay.com/ebaymotors/LINCO...Q5fAccessories
![]() ![]() Last edited by ratrodmiller; 11-29-2010 at 10:19 PM. |
#10 | |
so you can look in everything from big Lincolns to 305 TBI Camaros... also some V6 sedans had huge fans, like the Taurus mentioned. |
Hollister Road Co.
If your to close for a mechanical fan you will never get a Taurus fan in there and you can't make a Taurus a pusher.
#12 | |
According to the seller (Ebay) the width is 5". I believe with the mechanical fan its 2' shim removed there should be enough room. I will certainly check it out before buying. Thanks for the heads up.
its been a while since ive measured my radiator, but on the 38' were working on, we used 2 of the slim 10" jegs fans. 2.5" from mounting to depth of the fan. they have a few other sizes too, but something to think about. and at 50 bucks a pop, its hard to beat.
i used a 14" flex-lite metal blade electric with no shroud thats only a tad over 3" that i cant seem to find on the internet. but it keeps my 400+hp cool no problem. but i will be upgrading to a dual setup with a shroud
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 |
I bought the Taurus fan on Ebay. I'll have to do a little fabrication to make it fit but it should work ok. Thanks for all the suggestions guys.
#15 |
I see you already bought one. But incase someone else need one, a Mercury Mistique uses the same fan.
1950 Chevy 3600 1951 Chevy 3100 1954 Chevy 3100 1954 Chevy 6400 |
