Old 05-27-2013, 03:37 PM   #1
Vova
C notch
How big of a c notch can I put in without lifting my bed?
Vova is offline   Reply With Quote
Old 05-27-2013, 06:46 PM   #2
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: C notch
That's about all, just the "C" notch. No step notch. Check out the Suspension section on here.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 05-27-2013, 06:58 PM   #3
nt30
Re: C notch
Not sure but from all I have seen on here it looks like there is room to throw 2" box tubing over the frame above the rear end and cut out the stock section. That would give you 4-6" of notch. Did it in the past on a mini truck and never had any issues.
nt30 is offline   Reply With Quote
Old 05-27-2013, 07:02 PM   #4
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: C notch
The top of the pig or center section will hit the bottom of your bed floor if you put anything more than a c notch in.
Old 05-27-2013, 08:12 PM   #5
nt30
Re: C notch
My bad. Thought there was enough room under there.
Old 05-27-2013, 09:58 PM   #6
Square_78
Square_78's Avatar
Re: C notch
I pulled out part of my old wood floor and did a 3" pipe notch. My rear diff bottoms out on my shock absorber crossmember before the axels bottom out in the notches. If you need anything more than a 2.5" notch in the back then you are in for a bunch of work. Tear out bed floor. Remove shock crossmember. Install step notches and raise carrier bearing up 2" to fix driveline angle. If you don't modify the bed floor then you will only get about 1" up into the frame before the diff hit the bed floor underneath.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 05-27-2013, 10:32 PM   #7
68shortfleet
Re: C notch
You can "C-notch" enough to get the axle about 1.5" into the frame before the differential housing starts hitting the bed floor.
Even though that 1.5" doesn't seem like much, it sure makes a difference in ride when you don't want to cut the bed floor.
68shortfleet is offline   Reply With Quote
