Old 06-12-2009, 11:29 AM   #1
JW76
JW76's Avatar
Hydro-boost
I have a 1982 c30 with the 6.2 diesel and the hydro-boost brake setup. The brake booster has what looks like a gasket right behind where the fluid lines enter (about an inch or so off the firewall) and the booster leaks from there. Has anyone had a leak there? Do I need to replace the whole booster or is it possible to just replace this seal?
JW76 is offline   Reply With Quote
Old 06-12-2009, 11:36 AM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Hydro-boost
I have the same setup on my 87. Personally not had this problem but curious to see the answers just in case.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-12-2009, 03:44 PM   #3
pig rig
pig rig's Avatar
Re: Hydro-boost
its a seal up in the booster itself and I've had this little leak and its easier to just replace the booster
I don't think you can get rebuild kits for them any more
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 06-13-2009, 09:30 AM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Hydro-boost
Just replace the booster/master cylinder. I have the same leak. Do you have to fill it with fluid every so often? If so, definitely replace both.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-13-2009, 07:00 PM   #5
JW76
JW76's Avatar
Re: Hydro-boost
The leak came all of a sudden. In one week I had no powersteering or brakes. At first the powersteering was a little stiff but the brakes were fine so I figured the power steering belt was just loose. Then two days later the truck wouldn't turn or stop. I looked under the hood and was like well then. The master is new. I put that in last year. I'll just have to replace the booster.
