10-03-2011, 01:08 PM | #1 |
Whats the best /cheapest way to seal drip rail?
I was thinking about heating up soem ofthe dynatron seam sealer i have tomake it flow smoother.. but im not too sure.. any advice?
10-03-2011, 09:04 PM | #2 |
Re: Whats the best /cheapest way to seal drip rail?
I just sealed it with plastic body filler. Thats what it seemed to be originally for my 69 Cst C-10. I dont know if you're doing just a quick fix or if you're doing a more complete resto, but I didn't have much trouble and it sealed it pretty well. Hope it helps.
10-03-2011, 10:11 PM | #3 |
Caulking, (you did say cheapest).
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
10-03-2011, 10:37 PM | #4 |
cheapest and best usually don't go together very well...if you want to do it right,get the 3M seam sealer and be done with it.
10-03-2011, 10:40 PM | #5 | |
I second that!
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 |
10-03-2011, 10:58 PM | #6 |
Active Member
I used the maxim self leveling seam sealer #824 for drip rails. It was like $37 after shipping and didn't require any special application gun.
10-03-2011, 11:16 PM | #7 |
Chevy Truck Addict
A trick my bodyman taught me is to have a little cup of thinner (and lots of rags handy), dip your finger in the thinner and smooth it out like you would with caulking. Works pretty good (if you're good at that sort of thing).
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
10-04-2011, 06:42 AM | #8 |
1969 Custom 30 wrecker
It's not cheap but I just got some POR 15 seam sealer that I'm going to give a shot on my wrecker project.
The 3-M and similar seam sealers ALL crack sooner or later and in my case(s), it's always sooner! Hoping this stuff will be the magic cure but we'll see...
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
10-04-2011, 11:22 AM | #9 | |
Does it fall into the same category as the 3M and similar sealers?
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
10-04-2011, 07:19 AM | #10 |
Cheapest isn't best. Use the two part stuff. I used the 3M in a caulk tube and it has cracked,although still pliable. I smoothed it out with thinner and rags as C10-Driver suggested. It may be just the paint cracked. I have to check closer. It takes a long time to cure being applied thick and maybe I painted too soon.
11-29-2014, 08:46 AM | #11 | |
*EDIT: Looks like I'm trying what Taskforce57 used
11-29-2014, 12:16 PM | #12 | |
the 3m fast n firm says not to apply over an etch primer. not sure which 3m product you used but maybe that is why it did not bond well. |
10-04-2011, 12:53 PM | #13 |
It is a good question and would also like to know which one will hold up the longest.
10-04-2011, 02:52 PM | #14 |
subscribed.
10-04-2011, 03:12 PM | #15 |
When I did mine I used some sealer I found at NAPA, the tube looked like it had been around awhile but I used it anyway, as I used it I could see a few air bubbles in it, I should have stopped right there but I didn't. As soon as the weather got warm I noticed the entire gutter had inflated, the sealer looked like a small innertube. I ended up having to grind the gutter out again, it wasn't that fun the first time but grinding out all that soft sealer was pure Hell! The point is when doing something like that it's best to do it right the first time! Don't go cheap if you want it to last! Make sure you grind out every last bit of surface rust you can get to and treat what you can't with some sort of rust converter. It sucks to have to do the same job twice!
Posted via Mobile Device |
10-04-2011, 03:27 PM | #16 |
VA72C10
good info here...anyone have a long term solution that's worked?
Looking for a 67-72 swb or blazer project in or around VA. |
10-04-2011, 08:32 PM | #17 |
Best stuff you can get IMO.. This is 2 part epoxy seam sealer that is self leveling. I paid $20/tube on sale but its normally $30 or so. Uses a standard caulk gun to apply. I recommend putting it on over some good epoxy primer.
http://www.evercoat.com/productDetail.aspx?pID=257
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see." - Thomas Jefferson 72 C10 SWB "Work in Progress" |
10-04-2011, 08:35 PM | #18 |
I think there is another thread on this, I'd like to know the best not the cheapest.
10-05-2011, 01:28 AM | #19 | ||
VA72C10
10-05-2011, 02:18 AM | #20 |
"the other guy"
i used 3m 2k self leveling seam sealer. i even have the gun for it. you can come check it out.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" |
10-05-2011, 10:10 AM | #21 |
I did a lot of research on this board and other Auto Body forums before I went with the Evercoat. I think most professional paint/body men would agree that for the price and ease of application you cant do any better than this stuff. Of course others will say go with the 3M stuff but most their 2-part sealer requires the special mixing gun which unless you run a shop is not worth the investment. This stuff is leaps and bounds better than what GM used from the factory, I'm only 28 and this stuff will probably out last me..
11-28-2014, 07:09 PM | #22 | |
11-16-2014, 04:06 PM | #23 |
subsribed
11-28-2014, 07:50 PM | #24 |
I'm in My cabs a leakin'
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
11-28-2014, 09:16 PM | #25 |
All about them K’s
I've had good results with lord fusor self leveling seam sealer. Got if from autobody tool mart for ~20 a tube. Uses a regular caulk gun and after 6 years in the drip rails of my '57 it still is holding up well.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
