05-21-2006, 10:09 PM | #1 |
What did you get done this weekend?
The only thing I got done truck related was pressure washing the engine/tranny and the front of the 71.Hope someone else has got more done than me,what did you all get done?
05-21-2006, 10:41 PM | #2 |
Re: What did you get done this weekend?
I've been busy painting engine and assorted parts. The original 350 gave up the ghost, so I'm preparing a crate 350 to drop in. But I couldn't live with that ugly black paint...so she's Chevy Orange right now. I'll post pics soon.
'72 Chevy K-20 Crate 350, SM465, 4.10's |
05-21-2006, 10:44 PM | #3 |
All Praise RANDY!!
We took out a 350 and put in another 350 all new and nice! It runs like a champ too! All retro-rollered-out too!!! Roller cam, lifters, rockers... OH YEAH!!!
Next up 700R4, then....static drop MY big ship!!! |
05-21-2006, 10:50 PM | #4 |
worked hours and hours,
got the 496 in and running Last edited by rage'nrat638; 07-12-2007 at 07:03 AM. |
05-21-2006, 10:50 PM | #5 |
sat i went to a carshow and today i finally got around to alingin the pullies on my '69. no more belt throwing above 4000rpm!! chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
05-21-2006, 11:04 PM | #6 |
I have a radical idea!
I went to an a salvage yard auction Sat. and bought 2 '67 Impala Fastback Super Sports and a front clip from a '67 RS/SS Camaro including the grille and headlight doors I drove the '67 C-30 to a local car show with the fam. Tomorrow I'll be using the '69 C-30 to bring the 2 Impalas home (2 70 mile trips) ...yay
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 05-21-2006 at 11:05 PM. |
05-21-2006, 11:00 PM | #7 |
Questionable
lots of hacking - rear crossmember installed - would have gotten gas tank mounted, but too much other stuff came up.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
05-21-2006, 11:09 PM | #8 |
Cut up some more old truck pieces to haul off for scrap later this week. I also got the engine dropped into the frame today. Forgott to get new some new flex plate and torque convertor bolts, so the tranny hook up and all will be later this week.
05-21-2006, 11:14 PM | #9 |
Mufflers and tailpipes ,at last!!!!!!!!
1987 GMC heavy half Shortwide-GONE 1971 LWB 350/350-GONE 1972 Buick Skylark (80K orig. miles,one family owned) 2002 Currie Phat Flyer (Pit Vehicle) STOLEN .............................................. |
05-21-2006, 11:12 PM | #10 |
I forgot to mention,the reason I only pressure washed was because I reroofed
my garage this weekend. Last edited by 1969k10stepside; 05-21-2006 at 11:12 PM. |
05-21-2006, 11:27 PM | #11 |
I wanted to do a leakdown test, possibly install new head gaskets if needed and install a new power steering gearbox, but I had to work both days this weekend......17hrs of OT...
05-21-2006, 11:28 PM | #12 |
71 GMC 454/TH400
I put a battery in my truck, that's about it. I wanted to cut my drive shaft and go for a spin but some one else had plans for me.............Arts festivals and bead shows are fun lol...........
"The bigger you are the harder you fall, the farther you walk the longer you crawl." |
05-21-2006, 11:28 PM | #13 |
Picked up new countertops in the 68, then installed them in the kitchen. Also went to a local car show.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
05-21-2006, 11:39 PM | #14 |
cut, weld, grind, grind, cut weld, etc, etc...
Installed old Air electric fans, cut, weld, grind, grind, cut weld, etc, etc... shaved firewall, cut, weld, grind, grind, cut weld, etc, etc... Whew! I need to go back to work to get some rest..
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! |
05-22-2006, 02:09 AM | #15 |
Washed truck, got tranny in and crossmember, Unbolted engine from correct holes (dummy) moved forward to the wrong holes, then moved back where it was before I got clever. That part was a *****! I could have been doing anything else Lesson learned! Started the custom fiberglass glove box single DIN holder. Removed vent windows for one piece Electric ones that will be a comin'!
05-22-2006, 02:46 PM | #16 | |
Fat Fendered Fleetside
Man this is agreat productive group. Congrats guys to all the work...
hey- sounds like my weekend. cut grind weld, etc. hahahaha I cut the front 3" off my frame, so I can mount my forward tilt front-end. I welded 2"x2" 1/4" thick angle in the frame, and radiused the top so the hinge will sit nicely. OK for driveway work.... .. I suppose. |M| |
05-22-2006, 04:14 PM | #17 |
Tailgate handle relocated & patch cut out & tacked in.
05-22-2006, 04:39 AM | #18 |
English Chevy Owner
Nothing as Friday night out with friends, woke up saturday with the hangover from hell, drove 200 odd miles to be at a friends 40th birthday bash, got up Sunday with a hangover, popped in to see one of my sisters on the 200 odd mile drive back. Plus for the last week or so it's been raining so hard here I've been waiting for Noah to come floating past collecting my two cats for a cruise!
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
05-22-2006, 08:21 AM | #19 |
Never Done?
Got my truck rolling, finally (http://67-72chevytrucks.com/vboard/s....php?t=200006). Took it easy yesterday, just cleaned up the garage.
05-22-2006, 08:27 AM | #20 |
Still Green but learning
Nothing truck wise, I watched the kids all weekend for the wife and did manage to cut the grass.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
05-22-2006, 08:54 AM | #21 |
Granddad's Ol' Truck
Took a trip up to Greenville, MS for the ShowFest event. Got in Friday early afternoon. Met up with a couple of the guys from Primedia and did a photo shoot with them later that evening. Saturday morning, I had to load everything up and rush back home due to a family emergency. Got to cruise around and enjoy my truck tough!
Oh, and finished swapping out the bed wood on Friday morning. Back to real Mahogany this time around. (Trying to match the steering wheel)
1971 Chevrolet Custom 10 short step-side 2005 GMC Sierra SLT 2500HD crew cab 2wd [I]1971 Chevrolet Custom 10 Deluxe lwb fleet-side |
05-22-2006, 09:03 AM | #22 |
C10 Club Tennessee
Went to the Huntsville Super Chevy show on Friday and bought a 72 Suburban while I was there. Worked the race track on Sat night as usual, then work later Sat night. Sunday spent it with my in-laws(AS USUAL ) Can't ever get out of that. Can't wait to pick up the burb on Wed.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
05-22-2006, 01:47 PM | #23 |
I put all new brake components on my wife's '68. Then I couldn't get any pressure to the rear. I put on a new proportioning valve, same thing. I got a brand new BAD master cylinder that wouldn't pump to the rear!! What a bunch of grief that caused. Anyway she'll stop on a dime now.
05-22-2006, 05:11 PM | #24 | |
computer illiterate
give us some details on the burb. i was down there saturday and saw a blue and white one with a real good body and a 402/th400 for sale
72 2wd blazer 72 swb 4x4 |
05-22-2006, 02:04 PM | #25 |
Red Headed Step Child
I put the emblems on my C-10 and started taking the power steering pump off for replacement. I got sidetracked by a motorcycle ride :-D
"Dinner, the perfect break between work and drunk" -Homer Simpson |
