Mudslides 'r my specialty
4" Spring/Hanger or 5" Flip Kit?
Does my truck sit low for stock?
![]() I think my springs have sagged (they are listed as HD on the build sheet). I am trying to decide between a 4" shackle/hanger drop or a 5" flip kit. I am afraid the flip kit might be too low since my springs are sagging. I am planning a 4' drop for the front (2.5" spindles and 1.5' springs. I also have a small hill for a driveway, and I want to be able to get up it without scraping... Thanks for your input
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 Last edited by 8t5Silverado; 01-25-2004 at 05:08 PM. |
yeller
Before you do anything, buy new springs if you think they are sagging. That way when you drop it you know exactly where you sit...literally.
![]() It looks like you have the light duty 3+1 springs (guessing by the way it sits)...they are pretty cheap to buy new.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Surprisingly, my glove box build sheet shows heavy duty springs and towing package.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
yeller
Buy new springs first then.
![]() Since you have HD springs, then I would do a flip...my 4 inch rear shackle hanger kit didn't make it looked like it was dropped 4"...simply because the rear already sat pretty high (HD springs as well).
thanks for the info.
Insert Witty Text Here
If you plan to buy new rear springs anyway, you can always buy drop springs. They won't require that you cut anything. They just bolt in.
I have a set of 4" drop springs that I bought for mine that I will be installing as soon as I get a relatively warm and sunny day. It looks silly right now with just the front dropped. ![]() Slonaker |
Go with the flip kit. I have the shackles, hangers as well as lowered leaf springs. In the long run the flip kit is cheaper, i guess it's cheaper in the short run too. LOL Correct me if I am wrong but with the flip kit you get the c-notch, in some of them anyway, and you won't have to worry about your axle banging the frame....like mine does. I really need to get that c-notch installed.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
yep, might as well go with the fip kit and do it right the first time. You won't be happy until it's done right.
Dennis |
Yeah, but will my truck make it up my driveway with a flip kit?
I have found new flip kits for $60 w/o a c-notch, but I would probably just c-notch it at the same time since I have access to a welder anyway.
Plays with trucks
showthread.php3?s=&threadid=79218&highlight=cnotch Here are some home-made c-notches from the suspension board you should check out...
Gary My Dad's Old Truck 1985 ![]() |
Here are my ground-to-fender lip measurements:
FD: 30.375 FP: 31.0 RD: 31.875 RP: 32.375 My suspension is all stock, so I am guessing a 1.5 front coil alone would simply bring me back to the height I already have on the FD (front driver's side)...
Plays with trucks
I added a pic...
here's a 6" drop on the back. And mine sat at about the same height as yours. This is the best pic I have to show.
Dennis |
#15 |
do a shackle flip.
#16 |
shavedchevy,
I can't believe that is a 6" flip. I guess a 4" shackle/hanger combo just won't cut it. Thanks for help guys.
#17 |
4''
4'' shackle/hanger...
#18 |
Ok, so a 6" Flip actually lowers our trucks 4" and a 4" shackle/hanger actually lowers our trucks 2", right.
So why do they call them 6" flip kits??????
#19 | |
Under construction!
Haha ![]() A 6" flip kit will lower the truck as advertised (6"). Shackles and hangers are worth 2" a piece. All shackles are adjustable 1-2" and my DJM hangers were too. ![]() No kit will lower your truck EXACTLY as advertised but close enough. ![]()
2001 Silverado bagged on 22's. *Sold* |
#20 |
wish I would have known that before I lowered mine. Whta would be involved in going to 5/7 from a 4/6.... or is it useless?
Dennis |
#21 |
Under construction!
If you have a 6" flip kit now, simply add shackles. Up front, new springs will do the job. It all depends on your current setup.
#22 |
ttt
I am probably going with the 5" flip kit (which can easily be made 6" or 7" with shackles). I am still concerned it might be too low given that I think my truck sits lower than stock already (sagging springs, I guess). I am not going to buy new stock springs before I do the drop, that just sounds like throwing money away to me.
