Old 04-10-2006, 02:32 PM   #1
shifty
Questionable
shifty's Avatar
Angry driveshaft crap - the stupid stuff we do - yolk info
okay - just FYI - all of the following trannies use the same yolk:
Muncie/Saginaw 3spd
T56
T-10
TH350
4l60E
Muncie M21
Probably are other ones, but that's a list just for reference. I found this out the hard way.
So... my engine and tranny shipped shipped with a cap in the end of the tranny tailshaft it to keep the fluid from running out. I thought it was just a red plastic cap - but there was a tube the same diameter as the yolk which was inserted in the tailshaft to hold that cap in ... i didn't know this, so it stayed in ...
Uh, I kept trying to stick a yolk in the end of the transmission and it wouldn't fit because of that tube - I tried every sticking in every yolk imaginable to man before I realized (while talking to the guys in chat), "Duh, there is an extra tube in here preventing the yolk from going in!"...then I notice after pulling that little tube out that, "DAMNIT my 3spd yolk woulda fit!"
So, I find out this info too late, after going to Summit to buy the "right" part and realizing it wouldn't fit (hence why I realized there was an additional piece to the tranny cap in the tailshaft).
Well, to add to it, before I figured out this juicy tidbit of info, I decided that while I had my driveshaft out I might as well pop out the U-joints (thinking I was going to need a new yolk) and I was going to need to shorten the driveshaft to fit. So, newer u-joints, less than 10k miles on them, DS in good shape, all with a yolk I thought was wrong.
Well, once I realized I had the right yolk already, I (was pissed and) popped my 3spd yolk into the T56 tranny all the way, slid it out an inch, then measured from mid-u-joint cap to mid-u-joint cap and realized my stock driveshaft and yolk for the 3spd was already within ½" length of the DS i needed - in other words, I DIDN'T NEED TO REMOVE THE U-JOINTS, I DIDN'T NEED TO REMOVE THE YOLK, AND THE 3SPD DRIVESHAFT WAS THE PERFECT LENGTH TO USE WITH MY LS1 AND T56. My driveshaft needs to be ~56½" and it is currently 56".
So, now I get to pay someone $60 to press in two new the U-joints that I didn't need to take out in the first place.
This is like the third time I've done something in this swap to cost time and money when, had I figured out what was really going on and not made a "newbie" mistake, I could have saved money, time and hassle.
Meanwhile, I just drove to a driveshaft shop in Marietta GA only to get screwed around by the guys that worked there and drive all the way back to work getting nothing accomplished after waiting an hour.
I swear, sometimes life just isn't fair
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-10-2006, 02:45 PM   #2
qksilver
Re: driveshaft crap - the stupid stuff we do - yolk info
prep and planning always helps but there are just times that no matter what Murphy is looking over your shoulder
qksilver is offline   Reply With Quote
Old 04-10-2006, 03:15 PM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
The Borg Warner Super T10,and 400TH uses the same yoke,I think all others are the same.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 04-10-2006, 03:51 PM   #4
cdowns
cdowns's Avatar
sounds like the yokes on you
Old 04-10-2006, 04:00 PM   #5
meathead95
computer illiterate
meathead95's Avatar
you cant press you new ujoint in with a bench vise?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 04-10-2006, 04:04 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
When I swapped to my 700R4 (27 spline) my 3spd manual splined shaft didn't fit. I think it was either 28 or 30 splines? I think my tranny was a saginaw? It sucked searching yard's for one that had the correct splines and fit my driveshaft!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-10-2006, 08:43 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I think you may have had something other than a Saginaw 3 speed then. I have two Saginaw 3 speeds in my shop now, and the yokes are the same as TH350, 700R4, etc, the common yoke.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-10-2006, 04:41 PM   #8
shifty
Questionable
shifty's Avatar
I had a 3spd saginaw synchronized (out of a '69). had 27 or 28 splines.
meathead, i probably could press it in - but i damaged at least one of them when punching them out, so if the shop is installing them for free after i buy em, i might as well let em do it.
Old 04-10-2006, 04:43 PM   #9
meathead95
computer illiterate
meathead95's Avatar
o i c it sounded like someone was charging you $60 just to press them in.
72 2wd blazer
72 swb 4x4
Old 04-10-2006, 04:52 PM   #10
farside847
farside847's Avatar
Doesnt the 200-4r use the same yolk too? Plus the 200-4r is almost the same length as the saginaw 3sp
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 04-10-2006, 09:54 PM   #11
Green Machine
Green Machine's Avatar
Don't feel bad happens to me all the time, even when you plan it out in your head, when it come time to do it, well, expect the unexpected. A little more time, a little more money.........
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-11-2006, 12:02 AM   #12
krue
Designated A-hole!
krue's Avatar
Hate to hear I'm not the only one to learn a lesson the hard way.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 04-11-2006, 02:30 AM   #13
Ron 586
RIP Mr Ron
Ron 586's Avatar
Hate to hear that you are having so much trouble with your truck project. Seems to have you frustrated a bit. I get that way too sometimes when I turn on my new computer, that's hooked to my new copier/scanner/printer, that I down loaded pictures from my new digital camera into....... AND I STILL CAN'T POST A DAMN PICTURE ON THIS SITE. Now I feel much better.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 04-11-2006, 02:43 AM   #14
71/454
Turbo Guy
71/454's Avatar
Just so I get it right I have a turbo350 and am putting in a super t-10 4spd are the yokes the same?
71/454 is offline   Reply With Quote
Old 04-11-2006, 10:10 AM   #15
shifty
Questionable
shifty's Avatar
It's possible. You need to know whether your yoke is a 27/28 spline or 32 spline. The Super T-10 came in a 28 spline and a 32 spline.
These transmissions use 27 or 28 spline:
GM TH-350/Powerglide/Super T-10/4L60E/4L60/T-56/Muncie M-21
These use 32 spline:
GM TH-400/ Doug Nash/ Borg Warner Super T-10 Transmission
