04-18-2017, 08:56 PM | #1 |
Name That Body Module - Column Edition!
I'm pretty new to my 88 GMC project and I was hoping for a hand identifying stuff for future reference.
What's going on here is a pedal swap for my NV4500 transmission and I just don't know what i need to keep. Here's a few pictures if anyone feels inclined to assist me. Thanks! Tim it's a cluster of a few things, i know that shiny one is a flasher. pretty certain this is my ignition switch. The only other one i didn't take a picture of was the starter safety switch at the base of the steering column. this possibly might be useful for others too, i hope so. thanks again for looking and if you want to see what i am up to i have started a project thread in the project sections up there!^^^ |
04-18-2017, 09:08 PM | #2 |
Re: Name That Body Module - Column Edition!
I think the thing with the heat sink on it is a wiper delay module. It goes into the back of the wiper switch.
04-18-2017, 11:16 PM | #3 |
I'm doing the same on my 85. I just removed a column from a manual trans truck to swap into my auto trans truck along with the pedal assembly and the 4500. I would think that everything you showed would stay if your just swapping the trans?
04-19-2017, 12:01 PM | #4 |
Cool! I still want to get to know my truck better if anyone wants to chime in
04-19-2017, 12:47 PM | #5 |
i believe that relay in the third picture is the horn relay, i remember having to mess with it on my 86 when i was hooking up a ambulance style horn
second to last picture is your low beam / high beam switch, pull your turn signal lever and you should see the rod move behind it. last picture is your ignition switch.... probably want to keep that |
04-19-2017, 01:03 PM | #6 | |
04-19-2017, 01:01 PM | #7 |
First pic is power window and lock relay.
04-19-2017, 05:14 PM | #8 |
You need to keep it all...
1) Power window or lock relay 2) IDK 3) Buzzer 4-way flasker horn relay 4) Intermittent Wiper box 5) High Beam (headlight) switch 6) Ignition Switch |
04-19-2017, 06:19 PM | #9 |
That first one is for power locks ONLY-windows have nothing to do with that relay.
04-19-2017, 06:34 PM | #10 |
Power Lock Relay
Cruise Control Module Convenience Center Wiper Delay Module Dimmer Switch Ignition Switch |
04-19-2017, 08:33 PM | #11 |
thanks guys!
04-20-2017, 07:49 PM | #12 |
04-20-2017, 11:16 PM | #13 |
Prolly to cancel your cruze control.
If that relay in the 1st photo came from under the center of the dash then I think that's a starter relay. My M1008s have that there. |
