Old 10-11-2021, 10:28 AM   #1
81ChevyC10inSC
81ChevyC10inSC's Avatar
Backup/Neutral Safety Switch (1981 C10)
Need some direction. I think mine went bad. Got a new one from the local part store....but my issue is mine has only 4 prongs and all the ones i either see locally or on line have a 5th prong. Also they dont have a metal mounting bracket or any place for screws to mount to the column for that matter.
My question is can i use this one some how? Is the 5th prong for something that was added for other years? Does the plastic body of the new switch just clip to the column somehow?
81ChevyC10inSC is offline   Reply With Quote
Old 10-12-2021, 12:39 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Backup/Neutral Safety Switch (1981 C10)
I betting your may be a stick ( Manual Trans) or your looking at wrong years option. 81-87 auto, or 85-87 Manual, 76-80 auto, 73-75 auto,
Try parts store or LMC the part is about $11 to $16 for the part.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 10-12-2021, 03:28 PM   #3
cfan10
cfan10's Avatar
Cool Re: Backup/Neutral Safety Switch (1981 C10)
I'm in the same boat only mine is two prongs the only connection is the green and blue wires.
Not sure something is broken off or not.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
