09-03-2002, 11:09 PM | #1 |
Header gaskets?
What king of header gaskets should i use on my 350?
09-03-2002, 11:17 PM | #2 |
copper is a good way to go...they are a little expensive around 36 buck but they are worth it they will never blow out and they hardly ever leak basically the last header gaskets you'll buy......i would stay away from the paper gaskets.....they work but just not for long, they eventually burn up....also a dead soft metal gasket would work just as well....
i think i found me truck! 78 Crew Cab Dually 454/TH400, Dual Flows, Edelbrock Intake, Cam, Lifters, Billet Grill, K&N Airfilter, Grant Steering Wheel, A/C, soon to be power windows and locks, lots of plans for this... ....gas prices go down please |
09-03-2002, 11:26 PM | #3 |
my brother has some of the Earls dead soft aluminum header gasket. They cost a Buttload of money, but they work awesome. I mean his header is warped sooo much. When he put paper gaskets on it, it leaked really bad. He put the Earls on it is perfect. The surround on them is reusable, but you have to buy new inserts when you take them off. I have tried the copper ones and they were allright. I didn't like the copper collector gaskets. Another thing about the earls is that they are a pain to put on. Hope that helps. Low68
Build Thread |
09-03-2002, 11:36 PM | #4 |
summit or jegs is a good place to buy gaskets....cheap and easy
09-04-2002, 12:19 AM | #5 |
ive had good luck with the fel-pro stock manfold gaskets..you know the foil looking ones
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
09-04-2002, 08:19 AM | #6 |
1969 Custom 30 wrecker
Go get yourself some $6.00 exhaust manifold gaskets. They work great and won't blow out. If you ever bought an engine gasket set, you may have some extra's laying around.
It also helps to apply a thin coat of RTV to both sides of the gasket during the install. This also improves the cardboard type.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
09-04-2002, 11:21 AM | #7 |
has anyone tried the Permatex Ultra Black silcone that sanderson reccommends on all of its headers, instead of a gasket?
Current owner of 2016 2500 Silverado Midnight Edition. Former owner of: 69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4 72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust |
