05-20-2005, 12:16 PM | #1 |
Question on 80 something frontend on 77
Thinking of buying a 77 which has an 80 something front end (dual square head lights) and was wondering what I would need to restore this to a 77 front end.
Any info is appreciated. Thanks. |
05-20-2005, 12:21 PM | #2 |
Crazy
You are probably going to need fenders, hood, grille, headlights, parking lights, side marker lights for the fenders and possibly a radiator support. That is all I can think of at the moment, I converted my truck from a 77 to an 86 a while back because the body was shot. Good luck.
77 SB Stepside in a bunch of pieces scattered around the garage. |
05-20-2005, 12:23 PM | #3 |
fenders, rad support, hood, lights, bezels, grille...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
05-20-2005, 01:22 PM | #4 |
www.73-87chevytrucks.com
To make it back to a 70's, you need the entire front clip.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
05-20-2005, 01:24 PM | #5 |
yea u need from firewall forward i went from a 78-89 frt clip but i live the burb slips better
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
05-20-2005, 03:30 PM | #6 |
Thanks to all. Still undecided, but will take another look at it tonight.
05-21-2005, 01:52 AM | #7 |
Street Rod Restoration
...same thing
Iam building the same thing 81 front end on a 76 good luck
Follow me on Instagram @ hot_rod_shop |
05-21-2005, 09:45 AM | #8 |
Dont forget your wipers! I think 73-80 trucks had shorter wiper posts(so the wipers would fit under the hood) and 81-87 trucks had taller ones(so they would stick up through the cowl)
Anthony 07 Tahoe LT 70 Chevelle 450HP 383-TH400 77 GMC Royal Sierra~Resto in progress~ |
05-21-2005, 03:19 PM | #9 |
Might want to take a look at the cowl area in front of the windshield. Make sure they didnt hack it up too bad if they installed the 81 and up hood hinges . If you are going to want it to look factory when converted back , that might be an issue. You might also check the front of the frame horns where the bumper bolts on .81-87 trucks had the front of the frame horns trimmed and a bumper bracket bolted on . 73-78 trucks are shaped a little different . Frank
05-21-2005, 09:38 PM | #10 |
f. monroe is very right, they hacked my cowl area all up and they added the longer wiper brackets as above mentioned. Here are the pictures I promissed you, later...
