Old 02-07-2008, 02:26 PM   #1
hewlett2002000
hewlett2002000's Avatar
finally pulled my cam.... what should i put back in?
well my truck dident slip timing so i guess it is something to do with the distributor... i know the cap is not cracked. i guess ill have to find out when i get my engine back together and in the truck. my plan is just to put a new cam, lifters, timing chain and gears, and get the heads rebuilt. i dont think the engine needs a rebuild but thats just a visual inspection. it just doesent look like its been that long since it was rebuilt cause theres not much wear. and since the previous owner said it had a recent rebuild i figure it wont hurt it. what do you guys think? anyways what cam should i go with? i was thinking just a RV cam but im not sure. any suggestions? i want a lope but not too radical. the way it was was perfect for me. i had a sound clip but it was on my desktop and the HD crashed a while back.
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 02-08-2008, 07:20 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: finally pulled my cam.... what should i put back in?
I would recommend you go to the engine & drivetrain forum and look around. A lot of guys have asked this same question.
My take on it is to contact the tech departments at the cam manufacturers. They know far more than 99% of the guys here. I know that comp cams has an on-line form to fill out. They will need all the info you can provide, the more the better. They have changed cam selection from a best guess to a fine science.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-08-2008, 09:16 AM   #3
protrash64
Resistance is Futile
protrash64's Avatar
I called Comp Cam directly and the tech gave me a part # over the phone. I purchased directly from them.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-08-2008, 09:18 AM   #4
LILRED66
LILRED66's Avatar
Good information/advice. Thanks.
LILRED66 is offline   Reply With Quote
