01-20-2023, 07:00 PM | #1 |
FS - Pair New Outer Tie Rod Ends
For Sale - Two outer tie rod ends for '71-86 2WD trucks. Fits '73-86 C10, and may fit '67-72 and C20 and C30 as well. Part #ES409R. These fit various models, search for the part number to confirm they are what you need.
Ordered by mistake. Brand new, never installed. Edit - Last call - $15 for the pair shipped in lower 48. Last edited by Arne; 03-25-2023 at 08:33 PM. |
01-21-2023, 01:17 AM | #2 |
67-72 parts collector,…
Re: FS - Pair New Outer Tie Rod Ends
I believe the 71-72 outer tie rod for c10’s is the ES415r.
The ES409r should work on the 73-87 c10’s and 88-91 2wd 1/2-ton suburbans, and c20/c30 trucks also. Good tip to have the buyer check the part numbers.
01-22-2023, 09:07 PM | #3 |
Thanks, Keith. I think you are right about the 71-72 C10 using the ES415R. I mis-entered that and will correct it. I think the 409 does fit the earlier C20s, though.
02-02-2023, 10:52 PM | #4 |
Now at "make offer", as I don't want to scrap them if possible.
03-25-2023, 08:34 PM | #5 |
