Old 08-23-2006, 01:29 AM   #1
QKENUF4U
QKENUF4U's Avatar
Thumbs up 95 camaro rear end ??
anyone know how hard it would be to retro fit a 95 camaro disc rear into my 71 ?
later
lance
QKENUF4U is offline   Reply With Quote
Old 08-23-2006, 11:19 AM   #2
70rs/ss
70rs/ss's Avatar
Re: 95 camaro rear end ??
Just cut the camaro mounting stuff off, buy the correct pads for your application and weld them on, making sure of the pinion angle. You may have fun finding brake lines to fit (go to ss brake lines and have them custom made) cause the Camaro will have metric fittings. I was going to go with a Caprice rear, cause they have discs and the same bolt pattern as the 5 lug trucks. Good luck.
70rs/ss is offline   Reply With Quote
Old 08-23-2006, 05:46 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you are just doing it for the disks, why not just convert your truck parts to disk instead of degrading your rear axle?
Disks won't help you much onless you are always hauling a butt load of weight, or in the mud.
Old 08-23-2006, 06:49 PM   #4
67chevemall
67chevemall's Avatar
keep the axle! Do you have discs up front? Cause that is all you need 4 real.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 08-23-2006, 06:12 PM   #5
GMC71k20
those axles are pretty weak so dont plan on puttin any power to them
GMC71k20 is offline   Reply With Quote
Old 08-23-2006, 10:11 PM   #6
chevybill
chevybill's Avatar
there is plenty of rear disc kits for your truck without changing the entire rear end.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 08-24-2006, 01:57 AM   #7
chevymad
You don't want that rear. It's only a 7.5" 10 bolt. They're really easy to break.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 08-24-2006, 07:58 AM   #8
Inthuwind
Straight jacket required
Inthuwind's Avatar
I kept my 12 bolt-threw in an Eaton posi and incorporated '95 Caprice 9C1 disc brakes on mine. Better to have a strong rear IMO. You just come up with a bracket to hold the calipers on. There is a thread by 383Stroker here somewhere with dimensions on the bracket-that's what i used. I'll try to find the link.
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 08-24-2006, 07:59 AM   #9
Inthuwind
Inthuwind's Avatar
Lookie here!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=180846
